sdowney717
Senior Member
- Joined
- Nov 13, 2010
- Messages
- 1,600
- Reaction score
- 118
- Location
- Newport News VA
I have 2 of these port lights which I cleaned up and painted with rustoleum hammertone brown.
I painted them because they will corrode. I like the appearance now. These are from 1970 Eggharbor.
And they are real glass not plastic.
The wing nuts came clean in a white vinegar bath. Then scrub with SS wool. I will clear coat them.
I pulled the old gasket out of the frames and scraped and scrubbed them clean.
I stripped off the old paint from the gasket using citri strip and it appears to have made them soft and usable again.
People over the years had slathered paint all over everything.
This shows how they fit inside the port light.
One of the screens has a rip in the bronze mesh.
I think I can clean them up with a white vinegar bath.
What would you do? Can you buy new bronze window mesh and how about the outer frame edge, looks like it is a pressed down piece of copper with the mesh sandwiched in between.
A couple little pull tabs have broken off.
