Penn Yan transmission
Discussion in 'Inboards' started by Bilito, Feb 21, 2010.
  1. Bilito
    Bilito Junior Member
    Hi all, newbie here
    Just got a 1980 penn yan explorer with a 351 and it has what I think is a velvet drive tranny.
    Two questions, well three actually
    How can I ID the tranny?
    I can turn the prop by hand if it is in any gear is that supposed to happen?
    I see there are what appears to be some water lines running to the tranny I assume they are to cool it down???
    The motor is bad and we plan to overhaul it so I have never seen it run, just want to know what is what
    Likes: 1,615, Points: 123, Legacy Rep: 2031
    There should be an ID plate with the model and reduction ratio riveted to it. On that engine you most likely have a 71. The clutches are hydraulic so there is little friction when the engine is not running-they are disengaged. There are water lines in the back to cool it. A rebuild kit is less than $180.00. If you have everything out, might as well put new clutches and seals.
  3. Bilito
    Thanks for the tranny info, where on the tranny should I find that ID plate? I am pretty handy is that rebuild a DIY deal?
    Not 100% sure if we have to pull the motor yet, going one step at a time.
  4. gonzo
  5. Bilito
    How do you check it once I get the motor going to see if needs a rebuild or not. The oil looks clean and does not smell
  6. gonzo
    It shouldn't slip but engage rapidly and you can check the oil pressure at one of the taps on the top.
  7. powerabout
    powerabout Senior Member
    You mean hydraulic lines going to a cooler....
  8. Bilito
    What to do
    I have the motor and tranny out and sitting on a dolly. I plan to send the motor out to be rebuilt. What should I look at on the tranny. What can go wrong with it??
    the tranny is attached to a bell housing, do I take the tranny off the bell housing? will anything fall off doing that?
    Bilito
  9. powerabout
    How about a photo?
  10. gonzo
    The bell housing is an adaptor to be able to bolt it to the engine. Get the manual and it will be easier to understand the transmission.
  11. Bilito
    Changing Tranny oil
    How do you change the oil in my velvet drive, I don't see a drain anywhere.
  12. gonzo
    The line that goes to the bottom has to be disconnected. There should be a screen with a spring there too
  13. Bilito
    broke the hose removing it
    Cooler hoses have been on a long time and one rusted end fitting broke in removal. How much pressure is in those lines???? I am thinking to get a pair of braided metal flex hoses.
  14. Bilito
    What is the pressure ???
    How much pressure is in the cooler lines??????
