Peninsular marine diesel engines
Discussion in 'Diesel Engines' started by janesci, Dec 24, 2012.
  1. janesci
    janesci Junior Member
    I was thinking of purchasing one of those Peninsular marine diesel engine with stern drive sets. Has any one used this maker before?
    Is it cost effective than Volvo or Mercrusier?
  2. Carteret
    Likes: 6, Points: 18, Legacy Rep: 137
    Carteret Senior Member
    Good engines and good service department. Very easy folks to talk to and get replies.
  3. janesci
    Carteret - Thanks for your comment.
  4. WestVanHan
    GM/Detroit 6.5 vs Cummins 6BT?
    Only reason to choose GM over the Cummins is space-there is no other reason why.
    None.
  5. powerabout
    powerabout Senior Member
    GM 6.5 diesel with a cast crank
    might survive as a NA engine but doughtful with a turbo
    How come Peninsular havn't moved on to the 6.6?
  6. FAST FRED
    FAST FRED Senior Member
    These are auto based engines , so they must be operated like auto gas engines.
    Full throttle to get up on the plane then a good pull back to much lower rpm for cruise.
    If you need rated HP or a very high percentage of rated HP, an industrial based engine will have a far better service life..
  7. Carteret
    The 6.2 and 6.5 were designed to be light duty diesel engines for the GM 1/2 ton trucks. I have had a turbo'd 6.5 in a 26' planning boat for 13 years now and have had good service. This is the same engine that is in the military Humvee and still is since 1984. I removed a Ford 351 windsor from my boat and installed the 6.5 and gained performance and fuel econonmy. In a previous thread I posted one of the DOD service manual for these engines.
    These engines are like any other diesel engine in the fact that they will last if you take care of them and know how to use them.
    Warm them up, cool them down, change oil, clean fuel, don't over rev, and don't overload.
  8. powerabout
    except who makes a high speed diesel with a cast crank..thats a very short list
    Saying that the crank usually breaks because the block main webs fail as its about as strong as a small block gas engine.
    Clearly thousands of them survive but a broken crank in a 6.5 is no surprise to anyone.
    this add says it all
    http://www.automotix.net/engines/65dieselengine.html
    We now offer NEW 6.5 DIESEL ENGINE LONG BLOCKS for auto, truck and marine/boat. Our new crate 6.5 L V8 diesel engines come with 3-year and 36,000 mile warranty. Our replacement 6.5L diesel engine long block outperforms the GM 6.2 or 6.5 diesel engines (original motor) and guaranteed to fit your Chevy truck, delivery pickup or boat. Our premium 6.5 diesel engine built to eliminate the common failures and defects of the original General Motors 6.5 diesel engine such as cracked block, broken crank, cracks in the main webbing, cracked cylinder heads, coolant in the oil, loss of power, hard starting, low oil pressure and oil contamination. Our new 6.5 diesel engine has some key features and engineering changes that make it truly a high performance 6.5 diesel engine -- Never before has this happened in the history of the US auto industry. Don't settle for less! For more information, call 1-800-942-7800.
  9. Silverbreeze
    Likes: 4, Points: 18, Legacy Rep: 13
    Silverbreeze Bruno Tideman
