parabolistic damage stability-SOLAS
Discussion in 'Stability' started by e.m.milad, Sep 22, 2015.
  1. e.m.milad
    e.m.milad Junior Member
    Hi every body,
    If any body solve a probabilistic damage stability calculation with autohydro, it is really appreciated if share them here. I need to do same with Autohydro.
  2. NavalSArtichoke
    Likes: 9, Points: 0, Legacy Rep: 83
    NavalSArtichoke Senior Member
    The correct term is "probabilistic damage stability".
  3. TANSL
    Likes: 933, Points: 123, Legacy Rep: 300
    The correct term is "probabilistic calculation". Stability after damage is not probabilistic.
  4. NavalSArtichoke
    The current SOLAS damage stability method is indeed referred to as "probabilistic damage stability", as can be seen in this publication from Lloyd's Register:
    http://www.skibstekniskselskab.dk/p.../5 nov 07/Den 5 nov jens Peter & Henrik E.pdf
    This term distinguishes this method from the older "deterministic damage stability" regulations which were in wide use before the new SOLAS regulations were adopted.
  5. TANSL
    I guess it is a matter of semantics. But I do not mind saying, N-Achoke, you're right.
