Overheated - Now starts hard, runs rough
Discussion in 'Powerboats' started by Boomvang, Jun 26, 2009.
  1. Frosty
    Frosty Previous Member
    When doing a leak down test you are supposed to lock the engine or it will move--very quickly and can be dangerous. You would normally lock at TDC. If your gauge showed leakage beyond what should be normal it would /could be going to the next cylinder where it would have a valve open.
    Iether way the head gasket has gone.
  2. Boomvang
    Boomvang Junior Member
    Thanks to everyone for the input. For the record, most input seemed to indicate that no water in the oil meant probably no head gasket issue. Shop suggested that the inside of the exhaust tubes had blistered and was cutting off the exhaust. (said they see this frequently). I checked and the exhaust tubes were fine.
    They also mentioned a slight chance of fried condensor. Put in new condensor (as well as cap and rotor). VAROOOOOOOOOM! Wow, what a relief. I'm back in the saddle.
    My sincere thanks to those who took time to respond.
    Steve
  3. Frosty
    You know theres lots of threads like this.
    The owner knowing nothing buggers up something by checking it out.
    The experts!! not even contemplating damaging a cap and a condenser doesn't put that into the equation.
    Ive never see a fried condenser and I would have thought that was electronic anyway??? But to fry a condenser way up in the distributor without damaging any engine components????? still not right.
    I don't think you overheated it in the first place.
  4. PAR
    I've burned up lots of condensers over the years, it's not hard to do.
    Any respectable mechanic would have a diagnostic routine to preform, which would include all the "usual suspects", normally this encompasses the ignition parts too. At least my routine does.
  5. Frosty
    I cant Imagine how on earth you fry up a condenser. Replace then yes fry No.
    But if he brought it into your shop and said Ive overheated the engine you would'nt look at the condenser and see if the dizzy cap was seated --or would you.
    How do you do a routine on the internet?
    As I say I dont think it was overheated, some guy on the slip with his hands in his pockets said "Oh youve probably overheated it"
  6. Boomvang
    Dear Frosty,
    I'm sure you're a fine chap and we'd enjoy a cold one together...in fact, I'll buy. Can't help but mention that your comments do come across, a bit...well...Frosty. Perhaps that's why you chose the name. I actually did the things mentioned on this forum first.
    -While I'm sure I can't match your level of expertise I wouldn't say I "know nothing". Kind of a leap on your part, wouldn't you say. ;) I'm not sure why you think I "buggered something".
    - I changed the condenser because my local shop suggested that they have seen them go bad on an overheat. I, like you, would not have thought of this. I'm quite sure that I damaged neither the cap or the condenser, however the shop had stripped one of the hold down screws a couple years ago and I wondered if lack of proper seal had allowed oxidation (a bit of grasping at straws, I'll admit). I basically changed the cap (and rotor) because I bought a tune up kit and it was easy to do while I was swapping the condenser.
    - I have the same question as you. Since the "fix" came when I changed cap, rotor and condenser, I can't be sure which was the actual culprit. I thought about swapping back to find out, but I don't think I will. As I have stated, I did clean up the (1 year old) cap and rotor, so I'd be surprised if they were the problem.
    - I can only chuckle at the pomposity of this remark. Maybe if you had seen the temp gauge, the smoke, the discoloration of the valve covers and the melted plastic shield covering the solenoid, you would feel differently. Alternatively, if you questioned that it really overheated, you could have asked why I thought that.
    As I mentioned in my original post, I used my basic engineering problem solving to deduce that the problem was somehow associated with something under the distributor cap, since a simple removal, clean up and reassy changed the symptoms so radically.
    Thanks again for your input, and I hope I can look forward to your expertise in the future. Guys like you who take time to share your knowledge on forums like this are much appreciated.
  7. Frosty
    Boom Thanks for your Post , very nice, Shame it was'nt that long on the diagnosis and included that bit,-- but never mind.
    yes Im a bit short, thats me.
    Yes you can buy me a beer, and Im sure we would get on fine once you got used to the short bit.
    I will take your advice and next time I will ask "why do you think you over heated it". The loose cap would have been moving about as the rotor arm turned. its not so much being water tight.
    Oh well--watch that temp gauge!!
    I assume you found what overheated it in the first place?
  8. Boomvang
    Thanks for the kind response. Yes, I could have included more info. When asking for help, I try to balance between enough info and making it too long.
    As to the "loose cap" being the problem, I don't think so, and here's why. I mentioned that one of the hold downs is stripped. Now that I think about it, it's been that way for at least a couple years. I just snug it down as much as I can and attach the spring clip and it's been good to go.
    In addition to this:
    1. When I was having problems, I pushed down on the cap while trying to start to see if I was having any issue with the cap moving...no change.
    2. I replaced the dissy cap but the stripped screw is still in the same condition that it has been for the last few years, and everything is fine. (It's actually the threaded portion of the dis assy that's stripped, I meant to get a tighten up on the protruding portion of the screw/bolt).
    As to "what actually overheated"...it's still a mystery to me. As I said, I changed the condenser, rotor and cap at the same time and the difference was huge and immediate. Since I did it all at once (poor problem solving technique, but good way too finish when it's late at night), I can't be sure. Given that the shop suggested the condenser was fried, and they work almost exclusively on boats like mine. I'm going to go with that. Like you, I have a problem with this because from a heat transfer standpoint, there are a lot of things that suck heat and get way hotter than than the condenser got. Maybe they very are sensitive to temperature???
    It's a mystery. But I prefer mysteries with gear that runs vs. gear that won't run.
    thanks again,
    Steve
  9. pistnbroke
    Likes: 40, Points: 48, Legacy Rep: 404
    pistnbroke I try
    sorry I am with frosty ( again) condensers dont fry ..go open or short circuit but its more likley that the heel of the contact breaker wore away reducing the contact gap eventully to nothing on at least one cylinder and retarding the timing so it started to missfire..some of the newer versions of this old technology are thermoset plastic....
