One-armed bow cleat?
Discussion in 'Boat Design' started by cluttonfred, Apr 30, 2024.
  1. cluttonfred
    Likes: 26, Points: 28, Legacy Rep: 15
    cluttonfred Senior Member
    What is this sort of cleat called, which Phil Bolger often included on his designs? It's basically a big canted one-armed cleat with a metal cross pin obviously intended for mooring and towing loads.
  2. Tops
    Likes: 118, Points: 43
    Tops Senior Member
  3. cluttonfred
    Yes, that's the one, but I think it's supposed to be used so that the strain goes on the hook and not directly on the pin. And what is it called?
  4. philSweet
    Likes: 610, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
    It's called a thumb cleat.
  5. cluttonfred
    Thanks, but I have never seen a "thumb cleat" with a cross pin like that, only the small ones for looping the sheet around or something like that.
  6. Milehog
    Likes: 179, Points: 43, Legacy Rep: 215
    Milehog Clever Quip
    I like it.
    thumb bitt or bollard
    horizontal bitt or bollard
    lay down bitt or bollard
    A livestock brand number or letter on its side is called lazy. E.g. 2 followed by a horizontal 2 followed by P would be; 2 lazy 2 P.
    Hence:
    lazy bitt or bollard
  7. rangebowdrie
    Likes: 141, Points: 43, Legacy Rep: 10
    rangebowdrie Senior Member
    philSweet is correct, it is a thumb cleat.
    The cross bar is common, the "thumb" part gives friction to resist the sheet pulling out of your hands and the cross bar gives a fast/easy secure that can be quickly released.
    Ones without cross bars served the same purpose, but were generally used on little boats for racing where one person would work/play the jib sheets in more-or-less constant manner.
    Ones with cross bars were also commonly used on small boat halyards, with the halyard around the thumb you would 'sweat up" the halyard and then secure it.
