PAR
Yacht Designer/Builder
- Joined
- Nov 12, 2003
- Messages
- 19,126
- Reaction score
- 508
- Location
- Eustis, FL
5,600 to 5,800 RPM if well tuned and propped at WOT under load.
There's no debate over this, I'm familiar with the engine, having owned several This is what they pull.
I do think there may be a misunderstanding about the distributor. I don't see a good reason to convert this engine to coil packs and a crank trigger. It's much more likely the distributor is still in place and the points, breaker plate and condenser have been replaced (a good option) with an electronic ignition upgrade.
So the question goes back to H180DSC, "where do the spark plug wires come from?" If the distributor, it's an electronic ignition upgrade, if on the other hand they come from multiple coils, then a whole different ball of wax.
I still doubt it's an ignition issue, but think it's fuel delivery. There's very little that can go wrong with either of the ignition types mentioned.
Honestly a mechanic can sort out the effected system in 5 minutes with some simple tests. Once you've located the system (fuel, ignition, controls, etc.) you can then focus on fault finding that system.
It'll look like this.
