Niru
Mr.
- Joined
- Jul 21, 2010
- Messages
- 50
- Reaction score
- Location
- Philippines
Good PM.
Just wanted ask some few advice.
from the attached pic, you can see i intend to convert a single hull barge to a double hull. (tank barge).
concerning the Inner Bottom Longitudinal (existing member)
from ABS rules. attached file
under requirement of "h"
- distance in meters (feet) from the inner bottom to the following point....
* as defined in 5-2-1/3 for cargo or ballast tank...
***since the inner bottom long'l (existing part) will be inside the cargo tank.
now the question is what if the existing would-be inner bottom long does not comply with the abs requirement of with use scantling head as "h".
from scantling calc of the "inner bottom long" showing:
SM top = 5.585 cu. inch
SM Bottom = 26.474 cu. inch
while using the scantling head from the requirement giving me a
5.963 cu. inch
well just asking and its obvious i cant use the other requirement for "h"
which is ... ***deck at sides amidship for "void space". though it will give me a shorter "h" compare to the scantling head.
what are thoughts?
thanks.
5.963 cu. inch
what are thoughts?
thanks.
