offsets
Discussion in 'General Computing' started by peter radclyffe, May 20, 2010.
  1. peter radclyffe
    Likes: 69, Points: 58, Legacy Rep: 680
    peter radclyffe Senior Member
    can anyone tell me please how to use a computer program to put offsets into, thank you ,pete
  2. marshmat
    marshmat Senior Member
    Peter,
    What do you need to do with your offsets? Are you looking for something that can do hydrostatic calculations, or something that'll turn your offsets into a surface model, or just something that'll give you a nicely formatted table?
  3. apex1
    apex1 Guest
    For which result Peter? To import them into a CAD machine or what?
    ahh, thanks Matt! (one shall not open a thread and reply half a hour later)
  4. peter radclyffe
    marshmat & apex, i need a 3 d drawing, & if possible the tonnage at the designed waterline
  5. apex1
    apex1 Guest
    A drawing like this one made in Freeship? Where you then could import your table of offsets?
    the pic. shows nothing real btw.
  6. Tad
    Likes: 209, Points: 73, Legacy Rep: 2281
    Tad Boat Designer
    Peter,
    Can you send (email) me the offsets? In a scanned table or XCell spreadsheet or whatever....
    see if we can get a hull out it....
  7. Landlubber
    Landlubber Senior Member
    Tad,
    You are a gentleman and a scallop.
  8. peter radclyffe
    the hull is ready to loft, i just need a 3 d drawing
  9. apex1
    apex1 Guest
    The easiest way I am aware of would be then to type the offsets in a excel sheet and import them into Freeship or Delftship.
    The Freeship tutorial whcihc comes with the freeware, handles the "howto".
    (I assume you have freeship)
    Regards
    Richard
  10. peter radclyffe
    thank you Richard i have the freeship you told me about downloading, but i cannot make it work, i feel so stupid, it may be something very simple, but ?
  11. Tad
    Tad Boat Designer
    So here's the wire frame, ends still don't quite make sense....funky sections aft around the prop opening....trying to reconcile the sections and the profile doesn't seem to quite work.....
    This is with stations and waterlines at 500mm spacing...
  12. peter radclyffe
    thanks Tad, it looks good
  13. peter radclyffe
    this dodgy video squashes it
  14. Tad
    Tad Boat Designer
    The preliminary surface...looks like we lost some fullness at DWL...I'll look at that tomorrow....
  15. Tad
    Tad Boat Designer
    At 8.6m length
    LOA = 28'2.5"
    LWL = 24'11"
    Beam = 8' 2.25"
    Draft = 5' 8.625"
    Disp to DWL = 17,416 lbs
    LCG = 15' 5.5" aft foreside of stem
    VCB = 18" below DWL
    WS = 268 sq ft
    WPA = 131 sq ft
    PPI = 700 lbs
