Hoyt, what a great idea!
Okay, I can do this! Let me recapitulate some of my questions and quandaries below:
1. In Chapter 2 - what does he mean by a half breadth, and how does this translate into an equation for solving the moments of inertia? I take it that a "station" is a vertical line through the hull at which a given moment of inertia is calculated - is that correct?
2. Also, in Chapter 2, any help with either the Bilge Method or the Mean Secant Method for determination of the wetted area would be appreciated. Maybe just a better explanation or a 3D perspective drawing would help to clear up where I am getting fuzzy on things. I can sort of visualize what he is talking about but I believe that an equation with a clear explanation of the variables would untangle things a little for me.
3. From Chapter 3, I believe that I have finally figured out how he is determining the Center of Bouyancy, in that it is the center on all axes between the waterline and the draught of the vessel - is that more or less correct?
4. Also from Chapter 3, he goes to great length to explain why the bow and stern ought to be longitudinally shaped as a "versed sine wave," and a trochoid, respectively, yet his example of his 30' cruising yacht does not seem to make much use of this design consideration. Is the wave theory that he is talking about still valid in today's thinking? Also, I was not very clear about the formation of the trochoid. Although lengths of the wave formed by the trochoid seem to be a function of the changing "chord" (that he calls the diameter) of the half circle. Again, a formula with variables would help clear this up considerably!
5. In Chapter 4, there is no drawing of the lateral plane, and so while I am able to sort of visualize it, I am not sure what I should visualize it in relation to. A drawing of the lateral plane and how it relates to other relevant forces might be helpful to me here. I suspect that some of these things might eventually become more clear the further I read in the text, but this was a bit fuzzy. For one, in my thinking, a plane is not usually something that is "shaped." The other thing about the determination of the lateral plane would be what he means by the percentages he uses. Is he talking about the forward bound of the lateral plane being set at a certain percentage aft of the further most point of the bow at the waterline - or what is he talking about? This older original edition may not be as clear as some of the later edited editions. Again, a drawing would be quite helpful!
6. I am going to have to table questions for Chapter Five until I actually sit down and try to work through an example to see if I have understood well enough what he is saying there.
7. In chapter Six I have two questions. The first is what does he mean by "winging out?" I am making the intuitive assumption from the sound of the term that he means that one should evenly distribute mass along the curve from the bilge of the hull to the waterline so that at any given angle of heel (up to where stability is neutral???) has the same vertical mass. Is my understanding of this close? I am assuming what he is saying is that the hull should be able to heel easily within a certain predetermined arc. But he is not being clear to me where the safe bounds of that arc lie. I would think there ought to be some margin for safety in not bringing the hull to heel too closely to the point at which its stability is neutral, and therefore easily compromised with respect to its righting arm. The other question I have is what he means by "h" being "the vertical distance between centers of effort and centers of resistance." Again, a picture, or at least a clearer description would help immensely!
Okay, I believe that's it for now! Thanks for all helps and aids well in advance!!!
