wet feet
Senior Member
- Joined
- Nov 26, 2004
- Posts
- 1,948
- Reaction score
- 685
- Location
- East Anglia,England
That’s a good point….
ahhhhhhhh! So probably no matter what I do it’s probably not going to fall apart.
Just as long as you don't let some bozo tell you to add wax to laminating resin. Confine it to flowcoating when the boat is near complete.If nervous,practice on a small item first.
I have to suspect that a lot of money is being spent on epoxy resin by amateur builders because the believe it to be "better". It may form very strong bonds, but a properly designed polyester laminate ought to be adequate for it's intended purpose if good working practices are followed. Outside the realms of high performance boats, a slightly heavier laminate with polyester may be a good deal less expensive and still function very well. It may mean you can't compete for bragging rights by not having epoxy where it isn't really necessary. A commercial user, particularly one building for commercial use, will have to satisfy regulatory bodies that their boat is up to the task and they will have to build it at a price the market can accept. Not only do they have to meet these requirements, they need to make enough profit to stay in business. A slightly heavier laminate will probably be a more practical proposition that a more exotic and thinner laminate that wouldn't resist nudging a post quite as well.
