new project
Discussion in 'Projects & Proposals' started by garrybull, Sep 11, 2013.
  1. garrybull
    Likes: 16, Points: 18, Legacy Rep: 143
    garrybull Senior Member
    wont be long mate.
    had the surveyor out yesterday to give an insurance quote.
    as it stands he valued the boat at £50,000 so pretty pleased with that.
    got to add a few safety bits before launch like fire extinguishers , fire blanket , smoke alarm , manual bilge pump , extra grab handles inside wheelhouse , stainless surround around the cooker , fuel shut off valves.
    he was more than happy with the build quality and said its one of the best built boats he's looked at for a while.
  2. TANSL
    Congratulations, is pleased to see that a technical values so positively your work.
  3. garrybull
    thanks TANSL
    the valuation could go up or down on other boats built due to build specs ie engines and electrics package will vary so valuation could be higher if you had more expensive engines fitted along with bigger spec electronics package and lower if smaller engines fitted.
  4. garrybull
    boat is almost finished now.
    got the folding ladder finished today and now only have a few small jobs to do which some can be done whilst boat is in the marina.
    i made a step/cover which helps for getting over the rails and it protects the steering cylinder.
    it can easily be moved if i need to get to the cylinder.
    im hoping to launch the boat next week so keep an eye out for updates on how it all goes.
  5. jorgepease
    jorgepease Senior Member
    Nicely done!!!!!! Can't wait, take video!!! ))
  6. Squidly-Diddly
    Likes: 189, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
    Seems impossible that simply splitting a good mono-hull and adding a spacer would create good cat-hull.
    Aren't they just too, too different for that to happen?
    Then again, I once figured "no way can you just put a cell phone camera up against a telescope and take good pics....gotta be some weird reason that can't work" but it works just that simple.
  7. Mr Efficiency
    It will be interesting, I just hope the thing just keeps heading in the direction it is pointed, at all times. Some boats of the kind don't always behave, in that department.
  8. JSL
    JSL Senior Member
    To answer Squid - Didd's question
    Seems impossible that simply splitting a good mono-hull and adding a spacer would create good cat-hull. Aren't they just too, too different for that to happen?
    Yes, that's the general approach and one builder actually did this with a 39' V hull mold of mine. But, in the end, each design must be thoroughly reviewed. One critical matter is adequate hull/hull clearance (space between the hulls) and there are guidelines for this.
    I have done several asymetric cats (some might call them tunnel hulls) from 20' to 68' and they have worked well.
  9. doggyd
    doggyd New Member
  10. garrybull
    i worked for them when they first got the big cat on the water.
    the plug , mould and cat was built in my workshop and i then worked for them for 3 years.
    there new 9mtr cat is nice but the finish internally is not the greatest.
    the boat performs really well and should sell pretty easy.
  11. garrybull
    theres a 5mtr tunnel cat built a similar way to mine built about 15 miles away from me and the tunnel clearance is pretty poor but it performs really well.
    will find out friday how it performs if the weather allows as friday is launch day.
  12. garrybull
    me neither mate.
    will have plenty of pics and video once the boat is in the water.
    launching this friday and if weather allows we will try and get out on the solent to see how it performs.
  13. doggyd
    doggyd New Member
    I have done my own projects like this, ie plug & mould building & can appreciate the amount of work, commitment & skill that has gone into this. For a one man band you have done an amazing job. I have my fingers crossed for your launch on friday, but fairly confident all will be fine. Hats off to you!
  14. garrybull
    props are now fitted and the boat now has a name.
  15. garrybull
    the launch didn't happen today as the transport guy let me down and he won't answer his phone to say why.
    its now going in on sunday.
    got the bait table mounted and some rod holders mounted on the radar arch.
