New launch! Towline (Static) Catenary calculator (www.thenavalarch.com)
Discussion in 'Software' started by thenavalarch, Feb 8, 2015.
  1. thenavalarch
    Likes: 16, Points: 8, Legacy Rep: 43
    thenavalarch Junior Member
    Hi
    www.thenavalarch.com launches the Towline (Static) Catenary Calculator
    This Excel sheet helps you do the following
    1. For given towline properties and maximum bollard pull, it calculates the maximum towline sag for varying values of tension and generates a curve
    2. For a given static towline tension, it generates the catenary of the towline
    3. Available in both SI and Imperial Units
    A youtube video can be found here:
    https://www.youtube.com/watch?v=KFL__uY4eSc
    Uses
    1. Extremely useful in Marine Operations and transportation, when the towline varies constantly
    2. It can be used to estimate the sag even when there are no tension meters to measure tension of the towline. In this case, the tension is varied from T = Towline weight to T = Max bollard pull
    and Sag is plotted vs Tension
    3. It can also be used to determine the catenary when the value of tension is known
    4. Useful in low water depth environments where sag becomes critical to determine underwater clearance of the towline
    References
    1. Recommended Practice DNV-RP-H103, April 2011, Sec 7.2.3 Static Towline Configuration
    For more information, please visit www.thenavalarch.com
  1. thenavalarch
  2. thenavalarch
  3. thenavalarch
  4. thenavalarch
  5. thenavalarch
  6. thenavalarch
  7. thenavalarch
  8. thenavalarch
  9. thenavalarch
  10. thenavalarch
