New boat problems
Discussion in 'Multihulls' started by foxfish, Jun 28, 2008.
  1. kengrome
    Likes: 25, Points: 0, Legacy Rep: 305
    kengrome Senior Member
    It's a good thing you moved the engine ... :)
  2. Guest625101138
    That is good news. Just a matter of keeping air away from the prop.
    I do think you would be better off putting effort into a nicely designed cat. Current one is at least useable now. I would be wary of turning hard at speed though.
    Rick W
  3. foxfish
    foxfish Junior Member
  4. rwatson
    rwatson Senior Member
    Have you tried different props?
    You can get adjustable props that allow you to experiment with the pitch. It sounds like the current prop has too little 'bite', and just thrashes at higher speeds.
    In a conventional hull this would be the first thing you would look at.
  5. brian eiland
    brian eiland Senior Member
    New Design Idea
    I've not had time to read your subject threads yet, but I do have an idea to pass before you...its a RIB with a unique hull...but you might not have to build it as a RIB initially.
    Please send me a private email as I don't wish to post it on the forum at this time.
    brian.eiland@gmail.com
  6. BHOFM
    Likes: 14, Points: 0, Legacy Rep: 247
    BHOFM Senior Member
    It looks to me like the engine is too far back, the sponsons
    need to be extended.
    But what do I know??????
    :p :p :p
