Need a design for mounting steering cylinder
Discussion in 'Boat Design' started by Tharayman, Jun 30, 2021.
  1. Tharayman
    Tharayman Junior Member
    20234D93-7568-4D19-9662-437F2F331448.jpeg E6B7DCC1-F246-4D43-A046-6C67691FC09D.jpeg 607DDE99-A8E8-4196-BF8D-8286D77999EC.jpeg So, my old steering cylinder from 1986 is leaking. Also the rudder is moved way to easily by the sea, so I am suspecting internal leakage.
    I got two of these nice brass, «looks like new» cylinders for 3000 nok. Problem is they did not come with any device for mounting them. I am thinking I could make a metal plate with a piece of stainless axle for the cylinder to sit on. But it could still potentialy jump off, as nothing will be clamping it down…
    have anyone seen a good pre-made design for sale?
  2. kapnD
    Likes: 554, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    Pipe clamp? They make heavy ones called riser clamps that have long ears that could be bent to mount flat.
    The mount must be rigid.
  3. gonzo
    Likes: 2,295, Points: 123, Legacy Rep: 2031
    They are mounted to the square end with a bracket that allows the ram to pivot. Steering rams will bind if the mount is rigid.
    philSweet likes this.
  4. kapnD
    kapnD Senior Member
    Gonzo, you are totally correct, I should have gone into more detail!
    Google search turns up mountains of information on mounting for steering rams.
