Navigation lights
Discussion in 'OnBoard Electronics & Controls' started by Mat-C, May 19, 2011.
  1. Mat-C
    Likes: 12, Points: 0, Legacy Rep: 141
    Mat-C Senior Member
    My understanding is that for vessels <12m one needs port & stbd navigation lights plus (at a minimum) an all-round white masthead light. Also that there should be a minimum 1 metre vertical separation between the sidelights and the masthead light.
    How then do 3-in-1 combination lights comply?
  2. Willallison
    Willallison Senior Member
    Mat,
    I think you're slightly confusing the rules for sail and powered vessels, but to clarify... from Hella's tri-colour installation manual:
  3. gonzo
    Likes: 1,555, Points: 123, Legacy Rep: 2031
    Tri-lights don't display a 360 white but the stern white light. The 360 is for anchoring.
  4. Mat-C
    Mat-C Senior Member
    Thanks Will, Gonzo.
    Didn't realise the separate parts of the light are individually switched, but that has it explained...:)
  5. murdomack
    Likes: 23, Points: 18, Legacy Rep: 282
    murdomack New Member
    I think you have mis-read the regulations. It says one switch for the tri-colour and a separate switch, or a different switch position, for the anchor light. These are two separate light units.
    Your anchor light can double as an all round white if you are under power, but you also need separate port and starboard lights in this condition. So you need four lights in total.
  6. murdomack
  7. welder/fitter
    Likes: 32, Points: 0, Legacy Rep: 423
    welder/fitter Senior Member
    Much appreciation for all who responded to this. As I prep my boat for sea, I'm pulling the mast & was going to put a masthead tri-colour on. Shamefully, my ColRegs knowledge is a bit rusty. You've not only answered an issue for me but have pushed me to re-read my ColRegs!
    Mike
  1. Florent
  2. cthippo
  3. munthersaif
  4. Gianf1041
  5. SV_Harbinger
  6. the brain
  7. Manie B
  8. ellawendy
  9. old man
  10. Ike
