You should look again at Intrepid. There is nothing cruising about it. For example, it has a 12 foot beam on a length of 65 feet. The draft is over 9 feet which really restricts access. Lastly, the fact that most of the crew has to be below decks. Also, consider the cost of hauling out a 60,000 lb boat at a commercial shipyard. Another consideration is the amount of crew you need to handle 1,800 sq. ft. of sails. The height of the mast is about 100 feet, so that is another major access restriction. Finally, and most importantly, what is your budget? This is a multi-million dollar project.
