sdowney717
- Nov 13, 2010
- 1,600
- 118
- Newport News VA
The old switch failed, got stuck which would leave the pump running.
So bought this $2 magnetic reed switch on Ebay. I had all the other parts here.
The reed switch will turn on the 40 amp relay which will turn on the pump.
I sealed up the wires to the reed switch and pulled the cube relay apart out of its case and put sealer on to keep it dry. Plan to put marine grease in the wiring plug. Used Loctite S30 polyurethane roof and flashing to seal this.
I am using that SS sheet metal to hold the switch.
I think it will work well.
This is an emergency type pump incase other pumps fail, and eventually plan to raise it up higher.
Power comes in on red wire shared to reed switch connected to green wire which grounds relay coil when water rises and lifts float.
The relay takes place of the original failed switch.
I imagine this could fail if some dirty sticky stuff gets stuck on the reed switch float. Although float has lots of side clearance
It has a plastic c-clip so can be removed and cleaned off.
