My new baby! 6.8 Meter fiber over wood fishing boat !
Discussion in 'Boat Design' started by Vulkyn, Jun 13, 2010.
  1. Vulkyn
    Likes: 46, Points: 28, Legacy Rep: 654
    Vulkyn Senior Member
    Yah Richard for the frame, figured ill get things started :)
    hmm then i need to look again, they cant go over 6 because the laser burns the wood .....
    Minimum 18 mm MDF then ... can i use any other wood ?
    Thx for ur help Richard :D much obliged !
  2. apex1
    apex1 Guest
    WHICH FRAME?
    For the mould or for the boat? Being MDF I assumed for the mould.
    We never tried CNC cut in our production, not worth the money for us. I don“t know the technical limitations or alternatives. Except router cut.
  3. Vulkyn
    For the mold, and yah i meant a router cut ... :) still navigating through the terms ....
  4. apex1
    apex1 Guest
    Routers go through any common size, find a pro CNC shop, not a bedroom operator with a old plotter table and a cd player laser.
  5. Vulkyn
    :D lol .... nicely put Richard yah i have the yellow pages and im going through them so far they the ones I found are "allergic" to MDF or wood and i am sure because it requires more precise setting not just load and cut.
  6. pedalingbiped
    Likes: 2, Points: 0, Legacy Rep: 33
    pedalingbiped Junior Member
    I have been watching your progress and the headaches.
    Are you aware that you can change your occupation when your done?
    The knowledge your picking up could be life changing.
  7. Vulkyn
    I hope i can do just that :)
    Thx for following up my thread, soon it will be less theoretical and more practical boat building with hopefully pics :D (When the plans arrive!!)
  8. Vulkyn
    After killing a good part of my brain cells, i calculated what i think is the M2 of the boat.
    sooo plans say i need 750m of 10x19mm wood.
    Assuming the height will be the 19mm then
    750 x 0.019 = 14.25 m2 outside surface area x 2 = 28.5 m2 total m2 area
    Volume of applied epoxy = 14.25 x 0.00125 (thickness of epoxy per richards calculation) = 0.017813 m3
    Denisty = mass / volume
    Mass = 1100 (kg / m3 epoxy denisty) x 0.017813 = 19.59 KG of net epoxy not including the gluing part ....
    Erhmm feel like i did something wrong .....
  9. Vulkyn
    The workshop !
    Well i had to take the idea of learning autocad just to prepare my workshop with optimal efficiency out of my mind !!(im nuts ..)
    I attached a night picture of my hopefully future construction site ...
    I was thinking of building a light weight metal structure to create an enclosed working area. There is a lot of wind with sand and the temp is too high to work in the open.
    I was thinking to enclose 12 meters x 8 meters.
    The ground is tiles and elevated a bit just needs a good clean.
    I prepared a list of what i will be needing to get things organized:
    1- Electricity, cables, fuse boxes, lighting
    2- Sound system for music (ok its a must!)
    3- Steel structure with heavy fabric for side covers
    4- Tools Electric
    5- Tools workshop
    6- First Aid kit (i know i will hurt myself some how)
    7- Fire extinguisher .. (fires are not fun in a workshop)
    8- Fan (bloody hot in summer 45 + degrees)
    9- Ventelation pump (get the pesky fumes away)
    10- Humidity and temperature gauges
    11- Mask / gloves
    Dunno if i missed anything else ...
  10. mihari
    Likes: 1, Points: 8, Legacy Rep: 30
    mihari Junior Member
    Here I butt in again...
    Instead of building a heavy construction, you could do a green house style construction, like these
    http://mortonproducts.com/hseries2.jpg
    http://www.exccelgreenhouses.com/wp-content/uploads/2007/01/commercial-greenhouses-wireframe.jpg
    http://www.igcusa.com/images/coldframe-starter-package.jpg
    I imagine that green houses in Egypt are not very usefull, thus mass produced frames might be hard to find. Still, you may custom make one. The idea is that the frames can be esily taken away, and placed elsewere (or even re-sold). The skin is usually pvc film, but it can be made from more insulative materials (you want to keep the extreme heat out). Venting it at night (cooler temperatures) and blocking the sun out at day (most of it) would be mandatory to keep the indoor microclimate viable.
  11. Vulkyn
    hmmm thats a good idea ..... more research and looking then lol :D
    And green houses to exist in Egypt for tropical vegetation (well for growing them in the winter.)
    But dont green houses keep temperature in? or could they be regulated ?
    Thx for point this out for me, hadn't crossed my mind ...
    Please feel free to "butt in" any time, your input is always welcome much obliged
  12. rasorinc
    rasorinc Senior Member
  13. Vulkyn
    Emo mode on
    Right :D thx for all your replies guys this is truly a multicultural knowledge portal ! If only more people would help out like you guys do i swear this world would be a much better place :)
    I am feeling all fuzy inside now knowing i can come here and find help when ever i am stuck.
    I could not have even started this project with out the help and support of the great members (and admins ;) )
    / Emo mode off ....
  14. apex1
    apex1 Guest
    If you schedule epoxy work for the night time, a green house/tent might be a alternative. See catbuilder s setup in Florida. It helps curing at high temperatures, but I doubt you can work inside at daytime. And a AC installation will probably come out as expensive as the entire boat hull.
    A good ventilated warehouse with insulated roof might be the better way.
    Regards
    Richard
  15. Vulkyn
    Yah green house seems the logical solution. Day time will be a problem but fans and proper ventilation SHOULD help. (unless it will effect curing and working), besides the temperature is starting to go down now.
    Working at night is a good idea!
    The problem of working outside is the amount of dust and sand (plenty of desert close by), so thats not an option.
    I was thinking of an iron structure (Ihave one over the roof of a small house there) if pull comes to shove with insulated roof. I will take some pictures of the existing structure i have for better reference.
