My boat any comments?
Discussion in 'Boat Design' started by tamkvaitis, Nov 28, 2005.
  1. tamkvaitis
    Likes: 1, Points: 0, Legacy Rep: 34
    tamkvaitis sailor/amateur designer
    I was looking to make the bulb keel light, just for safety, I want self righting boat.
  2. tamkvaitis
    What do you think about this? My last creation
    L 5 m
    B hull 125
    SA upwind 35 sq m
    Cheap and fast daysailer, "slightly" overpovered, built from ply, flat botomed.
    Rear hidrofoil was just a thouth, i drew without any calculations :D
  3. Raggi_Thor
    35 sqm seems to be alot....
    I still don't like the flat bottom :)
  4. Tim B
    Tim B Senior Member
    tamkvaitis,
    What software are you using to draw your design ideas?
    Tim B.
  5. tamkvaitis
    Autocad mainly. I know that the render quality may be poor, but drawing internal and structural components is very easy, basicly all hardvare are using cad drawings (as I know)
  6. tamkvaitis
    I have re-calculated the sail area it apears to be smaller than 30 sq m. It is not quite clear from this pic, but i am instaling boiancy pod on the end of the outriger (the flat surface should be a boyancy pod). Question of flat bottom is realy interesting, I have played with many diferent types of design (multi chine, radius chine), the reason I designed this boat flat bottomed is:
    1. It should almost all the time be sailed flat (2-3 strong Lithuanian men on the 1.5 outriger)
    2. Bigger part of the time it should be sailed with true wind angle more than 90 degrees
    3. Flat bottom (if sailed flat) should give more dynamic lift, so it would start planing easyer.
    I am looking forward for your opinions ;)
  7. Tim B
    Tim B Senior Member
    Ah, ok, I've been using Rhino to do a preliminary design recently, same sort of thing (except 35' (10.66m)) long. When I've finished the interior I'll post a render.
    Tim B.
  8. Howgegoboat
    Howgegoboat Junior Member
    Designs
    Hi,
    Just a thought have you looked at Dix designs, they have good designs with rounded chine plywood construction.
    Or the john welsford sweatpea.
    Yours ideas look good, don't take boat design too seriously as some would!
    Yours James
  9. tamkvaitis
    My "new" design. radius chine plywood.
    Lol 8 meters
    Bmax 2.50 but it has small wings so the beam is slightly smaller
    Draft will be no more than 1.7 meter
    Powerfullmainsail and small 100% jib, I think with jib sheet 1/2 system winches wont be needed.
    Crew 3-4
    SA upwind abaout 35-40 sq meters
    Now I am thinking of lightly redesigning it. I want to make it narower, with remavable wings and retractable keel, it would be easyier to trailer.
  10. Raggi_Thor
    Have you estimated weight, ballast, displacement and stability.
    It's a lot of sail :)
  11. PATDave3
    PATDave3 Previous Member
    That boat is so freakying gay looking it makes my horney!!!!
  12. PATDave2
    PATDave2 Previous Member
    That boat is gay patdave3 is right that boat looks stupid you should put some guns on it or something and go around shooting people than the boat would be cool
  13. PATDave3
    You are so right PATDave2, he should put guns on the POS boat, then go and kill the forum admins for being douche bags.
  14. PATDave2
    Ya for blocking me thats just so mean and FREAKING STUPID GAY big fat heads just jealous cause i sail the blue seas with the titanic
  15. PATDave2
    If you guys un ban my patdave account i will behave and not do any more gay things i really know alot about boats like how they move and how they look like boats and the way you start it well normally use a key and chicken tacos are really tasty
