Mvp portable pump enclosure
Discussion in 'Boatbuilding' started by Anthony Avery, May 20, 2022.
  1. Anthony Avery
    Anthony Avery New Member
    I am trying to build a portable pump enclosure has anyone done this? Trying to keep my portable gel pumps clean and free of overspray.
  2. fallguy
    Likes: 2,041, Points: 123, Legacy Rep: 10
    Probably not gonna work with a passive system, unless it is just above it. Something with a even a cheap furnace filter is going to affect airflow. You probably need a small, cheap ac enclosure fan, think computer fan..filter intake air. The filter is in front of the fan and the air coming in is grabbed by the filter. Probably need nothing on the way out because that is all outflowing air..
  3. ondarvr
    Likes: 768, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    Are these the small portable units, Pail Riders, or the larger ones on carts?
    I've seen a plywood house built on the cart with a door or two for access to everything, or a loop of metal rod or pipe above the unit and a shower curtain hanging from it. Both do a good job of protecting the equipment.
    fallguy likes this.
  4. ondarvr
    One other option is a cardboard appliance box or two taped together. Wood and cardboard do potentially add a slight fire hazard if catalyst and gel coat are spilled on it though.
    fallguy likes this.
  5. KD8NPB
    Likes: 40, Points: 28
    KD8NPB Senior Member
    I built my Pail Rider on a metal pallet, a 4x4x4 ft box.
    it’s insulated with 1/2” foil foam (foil facing in), with a small radiant heater inside.
    during the winter, it maintains the pump and material at any temperature we set. We usually run it around 85F to compensate for cooling during spray.
