Motor Sailers?
Discussion in 'Motorsailers' started by Viceroy, Apr 2, 2002.
  1. Pericles
    Likes: 141, Points: 63, Legacy Rep: 1307
    Location: Heights of High Wycombe, not far from River Thames
    Pericles Senior Member
    Fair enough, let's keep the term Motorsailers for monohulls with pilothouses. Mooring and going ashore in a good sized tender is what I would have in mind, because the clamour from other vessels is minimized as well as saving money at the slip. As far as self righting is concerned, while monohulls often roll back upright in a knockdown, that 10K keel will sink the boat like a stone if it fills with water.:eek: :eek: :eek:
    Cruising catamarans have a nearly flawless safety record. A well built, well designed boat is safer than its monohull cousins because of width, stability, and righting moment. Most cruising catamarans are unsinkable, and the foam core boats generally have enough flotation in the foam alone to keep the boat afloat many times over. Having enough speed in many cases to stay ahead of weather is another great safety bonus.
    Racing catamarans and trimarans take calculated risks to push speeds to unbelievable levels. While these boats do end up upside down from time to time, rarely is anyone hurt.
    Speeding downwind, even with bare poles, in a catamaran can be unsafe, so streaming a drogue aft should improve matters. Heaving to with head to wind with a sea anchor and with dagger boards raised, will allow the twin hulls to slide over and lift with each wave passing underneath as there are no keels to cause the vessel to trip. I suspect a modern catamaran will survive far worse weather than the crew can.;) ;)
    I guess we can leave Brian Eiland to have both the first and last words in the matter of Monohull verses Multihull powersailers / motorsailers. http://boatdesign.net/forums/showthread.php?t=4499&page=11
    Regards,
    Perry
  2. brian eiland
    Likes: 253, Points: 93, Legacy Rep: 1903
    brian eiland Senior Member
    Tri vs Cat (racing single-handed)
    In a single-handed situation, I do find the trimaran configuration much more preferable for racing across the ocean. It is just more 'predictable' in heavy or gusty conditions.
    No question the catamaran form at larger sizes is more cruising friendly.
  3. Pericles
    Brian,
    In my dream I'd have a full complement of 5 personnel plus me on board the Gunboat 66. :p :p :p :p We wouldn't be racing Groupama 2, only shadowing. Single handed and racing, I think I would still prefer a Catamaran, because for boats of equal length, I think (could be wrong here) the Catamaran is slightly quicker for reasons of less drag. I've seen videos of Trimarans flying on one sponson in calm waters and it was awe inspiring, but to finish first, first, you have to finish and such grandstanding in the cold South Atlantic? Brrrrr. :D
    Best regards,
    Pericles
  4. Guillermo
    Likes: 199, Points: 63, Legacy Rep: 2247
    Guillermo Ingeniero Naval
    Three 'Royal Kings' just 'caught together' at the Frisian islands (Skylge), by friend Hans S.
    Fisher (43?), Banjer 37 and Dartsailer 38 (Hans') in a row.
    Aren't they beautiful? :)
    Cheers.
  5. charmc
    Likes: 78, Points: 0, Legacy Rep: 840
    charmc Senior Member
    Beautiful and comfortable.
  6. OldYachtie
    Likes: 1, Points: 0, Legacy Rep: 10
    OldYachtie Junior Member
    Core doesn't provide that much floatation
    "the foam core boats generally have enough flotation in the foam alone to keep the boat afloat many times over" - :eek: Actually, this is not true. Did you ever do the calcs for an actual catamaran and check this out? I have, and it wasn't true. A 65' boat with 5000 square feet of 1" thick core = 416 cubic feet = 26,666 pounds of displacement. On a cat there are lots of places to put some 2# polyurethane floatation foam, so you can give one positive floatation, but I wouldn't count on the structural core to provide it all without doing the math.
  7. Ronald
    Ronald Junior Member
    Noordkaper
    The Noordkaper is an nice yacht with classic lines
    She is ocean going, has a safe deckhouse and deck layout.
    The Noordkaper is easy to handle an there is a range from 40 till 60 feet.
    A hydraulic Centre board keel for a shallow draft and good sailing performance.
    A engine room with place for a generator hydraulics and al you want.
    Big tank capacity (in a 40 feet 900 litre diesel).
    The boats are custom build you can have a interior who is fit to your personal wishes.
    A perfect boat fore long cruising
    See also on www.noordkaper.com
  8. brian eiland
    You are right Ronald. She has sweet lines, particularly the 55 shown under classics heading.
  9. Ronald
    Noorderclassic
    The 55 feet is a Noorderclassic indeed a nice design as well.
    The Noorderclassic is not a motorsailor but the deckhouse is useful as well.
  10. RHP
    Likes: 90, Points: 28, Legacy Rep: 1183
    RHP Senior Member
    I hope they provide storm boards for the wheelhouse windows.
    There's so much glass there you could grow tomatos on the chart table.
  11. Pericles
    From the website.
    "Both styles of deckhouse are fitted with insulated security glass together with insulated frames to prevent condensation."
    Storm boards?
    Pericles
  12. Ronald
    Windows
    The windows are from indeed thermic isolated security glass and styles.
    They are also stronger than a surveyor advised for ocean going yachts.
    Al lot of glass is nice to view around.
    Deckhouse is very safe and comfortable place to be, during rain, storm, nights, etc etc..
    Of course you can have stormboards as well.
  13. Pericles
    Then how do you see out through them? :D :D
    Pericles
  14. Ronald
    Now you know why we do not like storm boards.
  15. Pericles
    OK, I'll play. Why did you mention stormboards in the first place? :D
    You can't see through them and the boat doesn't need them. Are you selling them? :D :D
    Pericles
