Mooring line tension error in AQWA ANSYS
Discussion in 'Software' started by Brany, Apr 21, 2017.
  1. Brany
    Brany New Member
    Hello. I have been using AQWA to find the motions of an internal turret fpso. I am using Worbench. I am testing two cases with 500m and 1000m water depth ,different mooring system for each. When I run the analysis of HTR (hydrodynamic time response) with irregular wave, the solve aborted with the error message as in the screenshot attached below. The error says: CCOMDB: ERROR OCCURS WHEN CREATING COMPOSITE CABLE DATABASE FOR LINE#1
    and !CCOMIL - COMP D/B - MAXIMUM TENSION TOO SMALL I.E. < 1.1*MINIMUM TENSION
    That happened in both the 500 m and 1000 m cases.
    I tried changing the configuration of the mooring system in order to get higher pretension but the error still occurs. The mooring design and the configuration are attached below. Have you ever encountered this before? I wanna know what I'm doing wrong. View attachment 500 View attachment 1000
  2. oataru
    oataru Junior Member
    Hi Brany,
    I'm from the same country.
    Didn't you notice that your maximum tension input was impractically so small for such scale of mooring problem?
    Check your cable properties again.
  3. Chiemela Victor
    Chiemela Victor Junior Member
    It is from the tension input for the mooring lines. It is very impractical to have such for your mooring lines. When you run the ANSYS AQWA solver, it will hit an error: CCOMDB: ERROR OCCURS WHEN CREATING COMPOSITE CABLE DATABASE FOR LINE#1
    This is because of the Maximum tension too small. It should not be. Check the cable properties. Ropes have flexible properties, but chains and loose links have a different flexible behavior as they are more rigid but held together by contacts in the link.
    Check it again, and let me know how it goes, if not sorted. I use ANSYS AQWA and Orcaflex for my designs and analysis.
    For further reference, you can check out my papers on:
    Strength of submarine hoses in Chinese-lantern configuration from hydrodynamic loads on CALM buoy
    hose https://www.sciencedirect.com/science/article/pii/S0029801818314550
    Composite risers for deep waters using a numerical modelling approach
    https://www.sciencedirect.com/science/article/pii/S0263822318302642
  4. Hahazy
    Hahazy New Member
    Hello, I have met the same problem (CCOMDP and CCOMDB ) in Hydrodynamic Responese analysis ( stability analysis ).My model is a multi-floating body ,they link to each other by nonlinear caternary(HMPE), as their distance is very small (0.5m),I define the cable in 1 meter ,so the cable is slack, but the initial tension is bigger than maximum tension(4000kN) that I define in caternary section. Actually, I doubt and want to know if you do the same pre-processing that define the wind/current force coefficient,connection point and connection cable( nonlinear catenary) before you solve the Hydrodynamic Diffraction and Hydrodynamic Response in workbench. I do not know pre-processing like this if have an effect on the next analysis in Hydrodynamic Diffraction and Hydrodynamics Response. Although the Hydrodynamic Diffraction run the *dat file in state 1-3 which do not contain deck 14 of mooring, and I examine the *dat file that deck 14 was none actually.
  5. Pan
    Pan Junior Member
    Dear Chiemela,
    I just read your paper: Strength of submarine hoses in Chinese-lantern configuration from hydrodynamic loads on CALM buoy. Very interesting and enlightening. But I have a question, why do not you just use one software during the whole simulation process instead of using AQWA first and Orcflex secondly? Is that Orcflex not able to obtain RAOs? Looking forward to hearing your answer.
    Best regards,
    Pan
  6. Frank Nsrl
    Frank Nsrl Junior Member
    Hi Chiemela,
    I've read your paper on submarine chinese lantern analysis on AQWA. I need your help, currently i need to perform dynamics analysis of flexible riser (Reverse Pliant Wave Configuration) and analyze motion response of Mid water Arch (MWA). However it seem like when i modelled my MWA and set it as a fully submerged structure, AQWA doesn't allow me and error occur saying "structure #1 (MWA) is set to fully submerged but it diffracting surface does not form an enclosed body. My question is how do your properly modeled a subsea structure which is fully submerged without diffraction surface in AQWA? Appreciate your kind reply.
    Regards
    Nas
    Naval Arch.
