Molded nonskid painting question
Discussion in 'Fiberglass and Composite Boat Building' started by pescaloco, Aug 14, 2012.
  1. pescaloco
    Likes: 10, Points: 18, Legacy Rep: 81
    pescaloco Senior Member
    Hello guys
    I would like to paint a molded gelcoat factory non skid deck
    My question is it possible to get good paint adhesion to molded non skid with out actually grinding down all the texture and starting from scratch.
    Is there a way to mechanically abrade the deck with out loosing the profile of the nonskid.
    Secondly it would seem that using a primer would fill the negative space in the non skid. Can a deck be painted with out primer.
    Or is this just peeling paint waiting to happen
    Thank you
  2. midnitmike
    Likes: 20, Points: 18, Legacy Rep: 167
    midnitmike Senior Member
    Boy thats a tough one.
    If I had to rough up a surface like that I'd probably grab a couple of different wire wheels and screw one on to my 4" grinder to see what affect that might have. As far as paint staying on it for any length of time... I think you got it right with the last line of your post.
    MM
  3. PAR
    A wire wheel will score the surface pretty quickly. A fiber wheel, which looks like a wire wheel, except it has man made fibers instead will be a better choice.
    Yes, use primer and yes to a very small degree, some of the low areas within the texture will fill, but we're talking a few mils of depth here, so not anything to worry about. A good primer surface is 7 to 10 mils thick. A human hair is about 7 mils, so you decide how bad this might be.
  4. tunnels
    tunnels Previous Member
    A light sand blast directly down from the top !.
    second choice would be a wire brush in CORDLESS DRILL ON SLOW SPEED use a detergent to get rid of grease wax and anything else that could prevent paint adhereing to a surface !
    i hope you got good paint !!!!:confused:
  5. Herman
    Herman Senior Member
    I have a product (Map Yachting Deck Line) which gives a rubbery anti skid surface, and their recommendation is HP cleaning, then wire brushing.
  6. CDK
    CDK retired engineer
    I think there are two options, but both have flaws.
    You can clean the deck, first with a HP cleaner, then a strong degreaser solvent and a wire brush to scratch the surface to provide a mechanical bond with 2C polyurethane enamel. Tunnels suggests a cordless drill, I would probably do it manually unless your deck has the size of an aircraft carrier. The spray painted deck will look good at first, but the paint on the tops of the no skid layer will wear and show where people walked frequently.
    Or you use an angle grinder to flatten the surface and apply a special non skid paint. I've tried several German products but was dissatisfied with their bonding strength on polyester. My own solution was spray painting with white 2C marine polyurethane, dust clean white sand over the wet surface and immediately spray paint it again. It takes a bit of exercise to distribute the sand evenly and the result is somewhat abrasive to the skin, but it is definitely non skid.
  7. Herman
    Do not use sand, but use polypropylene spheres instead, if you want to go this route. Otherwise you will never be able to get it off again. Anti skid properties of these systems is limited. (which is why I like the MAP Yachting stuff, soft, rubbery, anti skid, and also suitable to walk on with bare feet, will not damage sailing suits)
  8. CDK
    Quite right Herman, you can't get it off again. I should have mentioned that.
    I have no access to PP spheres, there even isn't natural sand here, only ground limestone or marble. A friend of mine was representative for a company near Munich that produces several coatings using these spheres, both acrylics and polyurethane based, but terminated the contract because of quality problems. Where the coating was applied indoors it performed as advertised, but outdoors was a disaster on any surface material, even porous stone. It seems to me the problem is the polypropylene that adheres to nothing.
    I have a balcony, done 3 years ago and subject to salt, rain and scorching sunshine. Had it done because it is a tourist apartment and I'm afraid of liability issues, but at the present approx. 80% of the coating has gone as small and larges flakes that are lying all over the place. This season is no problem because it hasn't rained in 4 months and I have the feeling it may never rain again.
    In case it does, I intend to etch the tile surface with hydrofluoric acid (HF). Very dangerous and unhealthy, but I lost faith in plastic coatings.
  9. Herman
    For concrete and other silicium containing surfaces, you could use a product called "Slipstop" which is used over here to do balconies and walkways.
    It etches the surface to a non skid sirface.
    Be careful with HF. Have a gardenhose ready to rinse any spills. Consider using phosphate acid instead of HF. HF might burn through the skin very fast, eating throgh the flesh and even into bones. Not a pretty sight.
    For coatings, the primers are essential. It should be doable, but your conditions are pretty harsh.
    PP should not matter. OK, it does not adhere well, but they are encapsulated in the thin coating (the coating should be thinner than the pshere).
    In greece there is a company "Kesteco" which has a lot of nice grits to sprinkle into an epoxy coating.
  10. pescaloco
    Guys Thanks for the replies
    I have been away for a couple days so sorry for my delay in responding.
    I have two questions
    Herman what is HF... and in the other post HP I assume is high pressure
    And how will one sand the primer that has been applied with out its removal using a wire or synthetics bristle abrasive
    Thank you
  11. CDK
    HF is one hydrogen and one fluor atom in a watery solution, called hydrofluoric acid or hydrogen fluoride.
    It aggressively attacks all body tissues, glass and ceramics. Because it leaves the solution as a colorless gas, it is one of the nastiest substances imaginable.
  12. Herman
    My boss left me a small bottle of HF solution on my desk. It was there where now there is a hole in my desk...
    HP = high pressure
  13. pescaloco
    Got it... I will stay away from HF
    Thanks
  14. pauloman
    pauloman Epoxy Vendor
    I faced the same issue this past spring. used a few cans of spray paint which fixed the color but didn't fill in the non skid texture...
    paul
    progressive epoxy polymers inc
  15. redreuben
    redreuben redreuben
    Microns perhaps ? 7ml is over 1/4 inch !
