Modify/extend existing mold
Discussion in 'Fiberglass and Composite Boat Building' started by mrdebian, Feb 1, 2023.
  1. mrdebian
    Likes: 12, Points: 18
    mrdebian Senior Member
    Hi all,
    I want to extend an existing small mold (it is a kayak rim) about 2cm on a specific area as outlined with the red marks in the attached image.
    I'm looking for opinions about the recommended way to achieve this.
    The mold is about 9mm thick made with gelcoat and chopped mat and polyester resin.
    Thanks
      File size:
      47.4 KB
  2. wet feet
    Likes: 627, Points: 113, Legacy Rep: 124
    wet feet Senior Member
    Do you have the plug available?It may make the job easier.
  3. mrdebian
    @wet feet I got two of those rims, in one of them I got the plug in the other one not.
  4. wet feet
    The easiest solution is to do the modification on the plug and to bevel the edges of the mould in the region so that you can securely place the mould in position and laminate the new section.There may be a small step,but it will be easier than trying to do the job any other way.For the component that doesn't have a plug,you will have a more difficult time,much more difficult.The most convenient solution would be to use self adhesive sheet wax of 3mm-5mm thickness if you can find any.It can be formed to a good approximation to the shape and then an extension to the mould can be laminated-very carefully.Again,you must bevel the existing mould and make certain that no surface that has been coated with release wax is left exposed to the area of the mould that you are bonding to.It will be best to double gel the new piece as there is likely to be an amount of finishing needed to get a perfect surface blend.
  5. KD8NPB
    Likes: 40, Points: 28
    KD8NPB Senior Member
    Add glass, grind to shape.
    sand back, spray with gelcoat with patch booster.
    sand gelcoat, buff gelcoat, wax
  6. mrdebian
    What do you mean by saying patch booster?
