Modern Aircraft Carrier
Discussion in 'Boat Design' started by Dook, Feb 19, 2005.
  1. cyclops
    cyclops Senior Member
    You sound very much like the very sucessfull Russian tanks and planes of WW II. Out produce them and use them in overwhelming numbers at any point of contact. 4, F-22 fighters are not stopping a group of 150 of any thing from going to their target, after they use up their missiles and go to guns. There is some safety and chance of sucess in large numbers. Always plan for the worst and-----,
  2. kach22i
    Likes: 111, Points: 63, Legacy Rep: 1222
    kach22i Architect
    Cool thread/design.............I like it.
    Torpedoes?
    Let's say you alter the design to be a soild sidewall SES or amphious hovercraft. Then it's always going to be something, like not too good in bad weather or surface to surface missles are going to get you, not to mention magnetic mines.
    You solve one problem only to create two more........that's life. :)
  3. D'ARTOIS
    Likes: 18, Points: 0, Legacy Rep: 321
    D'ARTOIS Senior Member
    Like in the ad's for ordnance equipment: you'll have a spoiled day.........and I am a very happy sub commander.
  4. kach22i
    kach22i Architect
    That is until you hit an uncharted underwater mountain. :eek:
    Hey, everyone's got problems, right? ;)
  5. D'ARTOIS
    That was in the time of the Akula, now we are 20 years ahead.........
  6. kach22i
    kach22i Architect
  7. D'ARTOIS
    Wakey, Wakey, thats yours.......
  8. D'ARTOIS
    Celltechnology outdates the LA class of attackboats. This one will probably scrapped - it had already maintainance overdue.........
  9. mfqrdf
    mfqrdf Junior Member
    We are really concerned about China. We also need to get a couple of boats done and into the fleet to replace the JFK and Kitty Hawk. Navy design takes forever, but we get high quality products that are overengineered and researched. Also realize that your design concept is actually a US Navy innovation. The US government is one of the major contributors to SWATH and Stealth designs, and you really have relatively little knowledge of these or their actual operations or what they need, other than what they let you know. Just have faith in them and their calls.
  10. brian eiland
    brian eiland Senior Member
  11. KCook
    Likes: 2, Points: 0, Legacy Rep: 13
    KCook Senior Member
    Wow Brian, just look at the depth of the trough behind the bow wave on that Sea Shadow. Can we say "fuel burn"?
    Kelly Cook
  12. Dook
    Dook Junior Member
    Sir, I am very familiar with US Navy operations. I can assure you that I have little faith in them or their calls.
    They take young American volunteers, strip them of their rights, and force them to praise brown clothed zombies who can't see outside of the box they've been put in.
    The US Navy is by far the most inefficient organization ever created. Where the term "Too many chiefs and not enough indians" is taken to the extreme. Their wasteful practises are putting this country right into bankrupcy.
    As far as this design goes, there is one point that kills it. It can't fit through the Suez Canal. So I think it needs to have a bottom shape like the current Nimitz design but keep the upper stealth shape. I was going to redraw it but "What's the use?"
    The navy's concern about this design was that it cannot sustain the same aircraft turn around rate of the Nimitz design because of the need to use the elevators to take aircraft down to the launch deck. Also, if the elevators fail then you cannot launch aircraft.
    While these these two points are true one is easily mitigated by redundancy, carrier electric and manually (diesel generator?) operated elevator motors.
    The other point is tough to beat. The aircraft have to take a ride on the elevators to go from the recovery deck to the launch deck, and this takes time. How much time? About a minute. I'm sure that those who don't like this design will argue that one minute can be an eternity when you need to support combat operations but the launch deck has a lot of room and it has four catapults that can all be used while you are recovering aircraft. You don't have to stop launching from two catapults just to recover like the Nimitz.
    All you need to do is have two JSF already fueled, loaded for air to air, sitting ready for the alert on the left two catapults and have two other JSF fueled, loaded for air/ground missions waiting at the back of the launch deck.
    I guess they never thought of that.
    Another thing they never thought of, one small enemy stealth (with design stealth, active stealth, or both) bomber approaching a Nimitz at night.
    You'd better hope France doesn't export one.
  13. SamSam
    SamSam Senior Member
    Do these things exist? What would the CIWS consist of? Sam
  14. safewalrus
    Likes: 78, Points: 0, Legacy Rep: 659
    safewalrus Ancient Marriner
    Dook, your age is? return the damn thing to 'Marvel Comics' where it belongs; best you go with it!
    luckily there's a 12 year old girl on another forum who is more adult than you are - she and her kind are the future of America - not 'superman comics inc!'
  15. mfqrdf
    Firstly I am training to be one of those so called "brown clothed zombies," but last I checked I'm getting educated to think outside the box and then some...so check your sources there, cause they're wrong. Also check out some of the great surface leaders such as Nimitz, Zumwalt, Burke...anyone with a destroyer named after them, and you'll see that they are far from mindless, despite the khaki.
    Other points:
    You can not overcome bomb damage with redundancy.
    Do you even understand what stealth does, with all known stealth technology the stealth still allows them to be visable, just at a reduced level of intensity...bombers look like birds, destroyers like large fishing boats, carriers like cargo ships maybe. Anyway what would be unusual are planes/helos taking off from cargo ships, and cargo ships driving around in a formation of x number of boats....kinda defeating the point.
    Wait annother 25 years for the technology to develop to the point neccessary for use.
