MISSING ID PLATE of inboard transmission
Discussion in 'Post-Tsunami' started by olsavan, May 22, 2006.
  1. olsavan
    olsavan New Member
    Hi everybody ! I have problem with inboard transmission ,i need bay broken parts for it end I dont know witch BRAND was made . Mi question is ,if someone of you can recognize the serial # of it? R 12563 J F C In the past the boat was equipped with 6 cylinders diesel DAF from buss. Inboard transmission is probably made in USA or UK because all dimensions and threads are in SAE.
    Repeating the serial #: R 12563 J F C and hope.
    Sincerely olsavan
    Likes: 2,315, Points: 123, Legacy Rep: 2031
    Did you loose in the Tsunami?:D Post it in the engines forum for a response.
