Note: This feature may not be available in some browsers.
This is the kind of project that sets my mind racing with ideas.Propulsion system needs work!
I'm already in the businessAwesome. Small solar system, battery and trolling motor and you are in business.
Indeed. I will be looking into reducing the 8kg this one weights, but I won't be looking into buying anything ready made. I'll get a shaft as thin as possible so it won't break, and may increase or decrease the surface of the blades. Not sure yet.To borrow a phrase from another boating forum, “ it looks tippy!”
As for the propulsion,A lighter, more ergonomic paddle with streamlined blades and a graspable shaft would help a lot.
Perhaps an extended kayak paddle?
Yes it definitely would. The possibilities are not endless but many.@Pedro re the video of you paddling along the canal, it might be feasible to have a pair of oars instead?
You could perhaps sit in the entrance to the cabin, facing forward, and have the oars mounted on oarlocks raised up on plinths on the gunwhales?
You would surely go faster than with a single paddle (although probably not much faster), but your centre of gravity would be considerably lower.
I would have taken your work for it, you didn't have to put it on a scale and provide photo evidence lolThanks for posting Pedro. My youngest is a fan of canal boats and camper boats and the like.
8kg paddle ?!?
My homemade stand-up paddle board paddle weights about 900g.
-Handle is 2m long, about 30mm square with rounded corners, made from 3 strips of red cedar laminated with epoxy. The clamping jig is a salvaged 2" (50mm) angle iron screwed to a wooden base. There is a t-bar grip from the same material. There is an angle cut into the handle allowing blade to point 'forward' as one pulls 'backwards'. The shaft and handle are finished with a clear solvent-based finish, no glassing.
-Blade is also cedar, maybe 9mm (3/8") teardrop-shaped, 98sqin [632sqcm) with a simple dihedral rib on the 'push' or back side. The blade is covered in glass cloth and epoxy (back side) and glass cloth and carbon fiber and epoxy on the front side and around the handle. Glass cloth is sufficient for strength IMO but carbon is 'fashionable' so I added it to the side seen by others, with a contrasting logo, as one paddles. I cannot remember which websites I drew influence from, most likely synthesized ideas from a few different ones...
View attachment 174247 View attachment 174248 View attachment 174249 View attachment 174250
