Gary Baigent
Senior Member
- Joined
- Jul 28, 2005
- Messages
- 3,019
- Reaction score
- 141
- Location
- auckland nz
This one,![]()
Note: This feature may not be available in some browsers.
This one,![]()
Do you have more details of "le couteau dans l'eau"? The text in the article you've posted is illegible and there's no link. There's a thread on Sailing Anarchy that mentions it with a good image. It seems the plan was to start racing it in 2014, but that doesn't seem to have happened. The Proto 650 rules change often, maybe it was obsolete before it hit the water and no one wanted to pay for upgrades?
Wonder if this interesting concept is what the AC designs will be like?
Entering dangerous (monohull?) territory?
A problem with Frog is that it is unstable at rest. And boats are at rest for a lot of the time. Have reduced this mistake with slightly larger floats - if you can call them that and set lower to water.
The compound bow beam here maybe could be simplified by just having it fixed through hull just above WL and then curving down and up a little from there? Would be less weight yet retain the same stability? But destroy the massive? accommodation luxury.
Arkema 3 the foiler / Quentin Vlaminck eventually finished today 6th of this second leg in the proto class (and 7th overall), quite far from the winner Griffon/ Ian Lipinski, 1day 21h behind. Average speed on water were respectively 9,4 Knots and 10,6 Knots (in Froude : 0,606 and 0,683). I have not yet the debriefing, but he clearly cannot take advantage of its foils on this pure downwind leg.
Otherwise, it is a confirmation for the scow bows domination. Thanks to sailingscuttlebutt.com, here below the comments of Simon Koster (Eight Cube Sersa), 3rd in this leg and first tester of foils on Mini :
“With regards the foils, we’re really going to have to rack our brains to analyse the pros and cons in terms of the weight estimate and the use you get out of foils. We know it will be impossible to have a boat that flies all the time, so the aim would be to have foils that aren’t a disadvantage when they’re not in use. "
“As for scow bows, we should have been doing this for a long time. It’s impressive to see how powerful these boats are. There’s no longer any doubt about whether they work or not. For bigger boats, the only issue relates to coming up with fairly solid structures. Unfortunately, the big boat classes have their hands tied in this area. "
Mini Transat: Proto podium filled >> Scuttlebutt Sailing News http://www.sailingscuttlebutt.com/2017/11/15/mini-transat-proto-podium-filled/?utm_medium=email&utm_campaign=Scuttlebutt%204962%20-%20November%2016%202017&utm_content=Scuttlebutt%204962%20-%20November%2016%202017+CID_8021a94b46d53b3f3acb1078483ea3a0&utm_source=Email%20Newsletter&utm_term=Full%20report
PS : Funny to note that the same day as Arkema 3, arrival of Arkema the Multi 50 as winner in its class in the Transat Jacques Vabre, for Lalou Roucayrol the skipper it is his first win in 9th participation in this transat ! . So not a bad day for Arkema team.
Which ocean racing trimarans start foiling in 4kn of breeze?…The lighter tri's can start flying from about 5knots of true wind. That is a much wider use of the foils. That would mean a full 2nd leg of flying this transat if the autopilot could do that!!
Unfortunately the laws of physics and safety mean that may never happen. Foils are an extremely unreliable source of righting moment and don't work at all when knocked down or capsized.If only we could make a monohull with wide foils and almost no ballast that can take heavy seas![]()
Unfortunately the laws of physics and safety mean that may never happen. Foils are an extremely unreliable source of righting moment and don't work at all when knocked down or capsized.![]()
As the lift exerted by the foils is a function of the squared speed, going from 4 knots to 10 knots means getting 6.25 times more force, which is not a small increase.At least below 10 knots.
The DNA performance TF 10 claims such numbers. But i check my source maybe i did not remember correctly. At least below 10 knots.
I know just foils ain't going to cut it but maybe a combination of semi buoyant foils in combination with self righting ballast but not more than that. Maybe combined with a canting mast, or a easy to depower sail who knows.
