Microwaving wood for bending, spring steel former
Discussion in 'Wooden Boat Building and Restoration' started by rwatson, Nov 11, 2012.
  1. rwatson
    rwatson Senior Member
    This might be interesting to a few people. Its been mentioned a few times on this forum, but seeing it makes it more understandable to me.
    Not only does he use a microwave for 'steaming' the timber, but has an innovative 'steel and jig' setup for forming the bend.
    Some good comments in the Youtube thread about soaking and heating times as well.
    The use of spring steel as a backing for tight wood bends is a good trick to remember on its own.
  2. Lawrence101
    Lawrence101 Junior Member
    Looks like the "spring steel backing" is actually a shop ruler :D
    Another good use for it tho , I have one just like it .
    L
  3. PAR
    A steel backer is a common practice when bending.
  4. Petros
    Petros Senior Member
    I have a similar homemade tool, but the form part is stationary on the backer board, and the metal strap is a length of plumbers metal strap with a layer of foam backed tape. It gives I think a better feel for the stress on the wood since I typically have both hands on the wood being bent (on the outside of the metal strap).
    I just boil the wood, you can put long lengths into a big pot, leave end you are not working out of the water. If I am curving both ends I work one end at a time. I have steam bent six foot long ribs this way. boiling is a lot more forgiving of defects in the wood, I have very few splits and failures due to grain run-out and other gain defects.
    Not sure how useful the mircowave is for parts longer than about a foot.
  5. waikikin
    waikikin Senior Member
  6. rwatson
  7. troy2000
    troy2000 Senior Member
  8. Outlaw45
    Outlaw45 Senior Member
    thats a craftsman. wow
    Outlaw
    1. sdowney717
    2. sdowney717
    3. sdowney717
    4. IwoodifIcould
    5. sdowney717
    6. CDBarry
    7. skaraborgcraft
    8. Rod Tait
    9. Brian Fredrik
    10. Person named james
