Mercury 2 stroke 150 outboard dies at full throttle
Discussion in 'Outboards' started by Bobs201, Jul 23, 2018.
  1. Bobs201
    Bobs201 New Member
    My 2003 2 stroke 150 merc runs fine at 1/2 throttle but dies out at full throttle after about 3 mins. It begins to sputter until I either ease off the throttle or it shits off. It it hard to start after shutting off and cranks similar to trying to crank it with the kill switch off. I have changed the fuel filters, had carbs needes replaced, new spark plugs. My mechanic thinks its a CDM, or Stator. Any suggestions on how to locate the problem?
  2. ondarvr
    Likes: 563, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    Try pumping the squeeze bulb right before it dies, if it stays running it's a fuel delivery issue.
    After it dies immediately check for spark.
  3. BlueBell
    Likes: 892, Points: 113
    Most likely a fuel delivery issue. Fuel pump?
    Second most likely, electrical; no spark.
    A mechanic may be able to swop some parts out as a diagnostic process.
    Has any work been done recently on the engine?
  4. Bobs201
    Bobs201 New Member
    Yes, in attempt to correct the problem, spark plugs, and carb kit
  5. Bobs201
    Bobs201 New Member
    Will a fuel pump or CDM/coil pack fail intermittently?
  6. BlueBell
    It's not an intermittent symptom if it's failing predictably after ~3 minutes at WOT and it runs fine at idle and 1/2 throttle, no?
    Preempted by sputtering (fuel starvation symptom).
    It wreaks of a fuel delivery issue.
    Fuel pump not being able to keep up or a dirty fuel channel in the carburetor perhaps.
    No work done previous to these current symptoms?
  7. gonzo
    Likes: 1,615, Points: 123, Legacy Rep: 2031
    You need a good mechanic to troubleshoot the problem. If he is changing parts to see if he gets lucky, go somewhere else. It may be one or a combination of problems.
  8. Mr Efficiency
    Likes: 1,039, Points: 113, Legacy Rep: 702
    Certainly sounds like fuel delivery issue, maybe blocked filters restricting the flow rate, ondarvr's suggestion ( have someone squeezing the bulb as you run along) would confirm a fuel issue, if it keeps running. You could have a fuel line that is sucking air at a connection somewhere along it, and if you have a spare primer bulb, switch, they can cause problems with age.
