PRE-PLANNED JURRY RIG
Now that reports of additional dis-mastings are coming in from from this stormy Golden Globe race, I have spent more time thinking about preplanned jury rigs. It is curious that I have ended up with a solution similar to the one originally posted on this thread.
At first I thought of how superior boats with shorter rigs were in this regard. This is because of two reasons:
The mast is shorter and, even though it may be heavier, it may be easier to some how hoist back on board the boat after it has been knocked down.
The boom will be proportionately longer, so if the mast is lost, it will be better suited as a stand-in mast.
The idea was to use the jib as a stand-in main by hoisting it upside down.
But as I thought about this some more, it occurred to me that short masted boats are not that common nowadays. And it would be a much better idea to come up with a system which would work with the taller masted 7/8ths and mast head rigs.
With solar panels and computerized auto-pilots, sloop rigs are now practical for blue water boats even with short, deep, wing like keels and spade rudders. The addition of a roller-furling jib makes them easier reef in a manner which insures proper balance. Add that to the fact that they do perform better than the long-keel, short mast, three sail types, and we have an almost certainty that these will be the dominant blue water cruising type. The long-keel, short rig types will become more and more rare (but will not completely disappear) as time marches on.
I decided that expecting the skipper and her/his typical one person crew to wrest the broken mast back aboard during storm conditions is too much to ask. So now I'll assume the mast and all of it's stays and shrouds will probably be jettisoned.
The problem is that the Boom on the taller masted type is usually very short, probably too short to use as a stand-in mast. Any solution I came up with would have to take this into account. The boom would probably be too short to even loft the clew of the working jib clear of the deck. It needs an extension.
It also occurred to me that the luff of this sail would probably be too long to allow using using the original mast step, unless some kind of makeshift bowsprit is to be set up. And even if it was, the CA of this new jib-only cat rig may end up too far forward. So now I'm convinced that the stand-in mast will be stepped considerably further aft than the original, maybe as far aft as the cockpit. This would be somewhat convenient as it will be not only easier to set up there, but will be easier plan local re-enforcement for as well.
But now the Boom needs to be even longer. The clew of this upside down jib has to clear the typical deck house now too.
And space on board a typical cruising boat is very limited., and so is it's carrying capacity. So carrying and extra spar which will probably never be used will probably not be a popular option. But what about an extension for the original Boom?
It could be made of the same extrusion as the boom, with maybe two bolt holes drilled through its sides. The Boom could also have two holes drilled through its sides. Sturdy aluminum plates or channel stock could be used to join the two together. Wood planks could be used for this purpose too. These joining pieces will probably need provision for lower back shrouds and maybe even lower side ones as well. The Boom will need provision for two back shrouds and and two side shrouds as well as for a fore stay. This could be done in a number of ways. One would be to provide for two simple hounds on the end that is to be on top.
The attachment points on the boat could be strategically placed cleats. These would have to be specially designed to be used for this purpose, as well as for their usual job.
The hull would also have to be locally reenforced to take these new vertical loads, which can be quite large.
Pre-cut rigging wire can be stowed for this purpose, with pairs of traditional cat-heads instead of the usual rigging screws. These will allow for a greater tolerance in lengths.
This new rig may go upwind reasonable well; but it may be a bear to get it to go down wind. Some sort of minimal drogue may be necessary to pull the stern upwind.
Though far from perfect, this pre-planned jury rig may mean the difference between having to scuttle the boat after an expensive rescue, or being able to reach port, saving untold tens or even hundreds of thousands of dollars.
For a 40 ft, 7.5 ton cruising sailboat, this may mean several hundred pounds of extra gear, as well as a spare working jib (which would probably be on board anyway). It may be seen as cheap insurance.
