Mike Inman
Junior Member
- Joined
- Oct 10, 2018
- Posts
- 55
- Reaction score
- Location
- Jacksonville, Florida
I realize this is a special form of insanity, but is anyone else making hull shapes using OpenSCAD?
Note: This feature may not be available in some browsers.
I've been trying but, not really having much success : (I realize this is a special form of insanity, but is anyone else making hull shapes using OpenSCAD?
Exactly what do you mean by "warped"?I was curious what software would be best for creating flat patterns from warped planes.
Any specific reason not to use Creo for developing the surfaces?Probably worth a try again maybe a combination of the 2 softwares. Export surfaces to Rhino for flat patterns.
Modeled a boat from lines I would like to build, that’s the goal.
You can check gaussian curvature with most of existing software packages. I think more important to have a good method for developable surfaces design.Any specific reason not to use Creo for developing the surfaces?
Creo Parametric Help Center http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/surfacing/surface/To_Flatten_Surfaces_Quilts_or_Solid_Surfaces.html
For a surface to be developable, gaussian curvature needs to be zero everywhere. You should be able to check that with Creo.
Hi,What is the software used for most of the designs in the Gallery section of this Site? Which would be the easiest to use for MacBook Pro 2013 OS High Serria?
