Manufacturing Aluminum Masts
Discussion in 'Boatbuilding' started by Mikey2, Mar 30, 2007.
  1. FAST FRED
    FAST FRED Senior Member
    Sprayed on?
    YES after all there being sold for Yachts.
    FF
  2. Mikey2
    Mikey2 Junior Member
  3. wet feet
    Likes: 106, Points: 43, Legacy Rep: 124
    wet feet Senior Member
    The reference in your link refers to heat treating after welding "Additionally, 6061 T6 losses half its total strength when welded. Consequently, a post heat treatment process is required to regain it's full T6 strength." An earlier post mentioned that the extrusion was tapered by cutting out a portion and then closing the sides together in order to weld the section back together.Perhaps if you add the heat treatment stage between items 3 and 5 in the list in post No 9 the process will be in the correct order.
  4. FAST FRED
    The mast builders I have worked with had no ability to heat treat after welding, they just welded the slit up and ground and painted.
    The boats we built were all CRUISERS , not racers , so the weight aloft was gladly carried for the extra strength.
    FF
  5. Mikey2
    Thanks for your responses, the size of these factories must have been huge!
  6. Mikey2
    Do you have to stretch them to straighten the mast out once extruded? or is this not needed?
    Thanks
  7. Mikey2
    Also what defects or quality checks have to be made?
  8. Mikey
    Likes: 7, Points: 0, Legacy Rep: 75
    Mikey Senior Member
    I would also like to know and you are the expert, please Fred :)
    Mikey
  9. lazeyjack
    lazeyjack Guest
    for what it is worth , the T6 is done after, but unless there are tests done and mill certs issued one can not always be sure of the temper, for instance I took delivery of 3 tonnes, flat bar for stringers in small ships, when we tried to form them for bending, they cracked--too brittle fortunately I picked this up early and the factory took it all back. they had just issued the mill cert without tests
    Thsi may explain why yacht mast collapse in column for no apparent reason
    T6 with form well look at the frames in my gallery, all t6 T section
    i have not been following, but a crowd in Bris Aust imports section from China now. there is huge profit in it, the cost may be as low as 5 a kilo, and sold as a mast section for huge profit, 30 a kilo?
  10. Mikey2
    What do you mean the T6 is done after? An how?
  11. lazeyjack
    lazeyjack Guest
    First it is squeezed through the die, then heat treated
    there is a raft of data, here is one link, try google heattreating to t6http://www.suppliersonline.com/propertypages/6061.asp
  12. Mikey2
    Hmmm, Ok, with that I have added that they are heat treated and quenched after the extrusion process... this correct?
    1. Aluminum 6061 Billets are melted down and extruded through the mast cross section die.
    2. Then it is heat treated and quenched.
    3. The extrusion is then cut to the length required.
    4. The top end would be cut and tapered and welded.
    5. Any other holes and fixings would be cut out.
    6. The mast would then be anodized.
    7. Mast would be prepped (alodine wash, zinc chromate primer, undercoat, LP paint).
    8. Final finish coat applied: Awlgrip.
    9. Any screw holes chased.
  13. lazeyjack
    lazeyjack Guest
    yes , cept if its anonized you would,nt paint
    And you dont need case threads
    By the way the only stuff that will last in Ally threading, is a stuff called lanacoat, made from natural sheep oil, its thick and smell of well sheep, and it stays there forever, we used it always and screws come out easily with it years down the track. It is a NZ product, so don't ask me where you will get it
    Are you building sticks?
    if youa remember try not to weld AROUND the section, particularly in the lower panel,
  14. Mikey2
    What quality control checks are carried out?
  15. mcollins07
    Likes: 11, Points: 0, Legacy Rep: 166
    mcollins07 Senior Member
    Is not the welding going to destroy the annealling? I suspect that this is the order that is practiced, but the heat treatment must be performed after the welding, if the mast is really T6. Otherwise, 6061T6 is just a starting material and the mast is not T6. Right?
