Looking for volunteers for testing a Rhino plugin
killwater
Junior Member
Joined
Oct 7, 2007
Messages
13
Reaction score
Location
Poland
Hello everyone
I wanted to ask if anyone would like to test a small Rhino plugin that is simply a bracket wizard. It helps to create a parametric 3d bracket model with live preview. Windows version Rhino5 is required as it uses lightweight extrusion object to save resources. Anyone happy to test the plugin can download the files here or on Food4Rhino http://www.food4rhino.com/project/shipwizard?etx .
To install plugin you need to place it to a folder that you wish to store it then simply drag and drop to rhino window. To start simply type in BracketWizard. There is another command for stiffeners but this should not be used as it is under heavy development.
Any constructive feedback would be greatly appreciated.
Ok, let's start debugging:
"Denisty" should be changed to "Density".
Bug squashed :cool: Thanks.
I know that undo is not working yet and that scalops can intersect the free edge radius if given values are to big.
New release with bugfixes is available for download.
Back
