I am working on launching what is easiest to describe as an oversized trailer sailer. It is a custom build and design - I have spoken to the designer, but he walked away from yachts some 7 years ago when he finished the build of this for health reasons and has no records of it. She has been through a few sets of hands before mine so it is a bit of a risk in terms of the design etc. I knew all this when I bought her, and so far I am quite pleased with everything but I have some reservations about the keel and would appreciate some advice.
It has a weighted retractable keel of 800kg - profile below waterline and metal scaffold above. So firstly how would I estimate the maximum load this will create when the hull slams down? is there a rule of thumb - 2-3G??
the keel box is a straight box section so if whatever I use to support the keel gives way there is nothing stopping it save the seabed - so I need a system to hold it in place. I am alternating between
Aluminium I beams through the keelbox and adding a support ring beam around the box to take the load or
using straps or dyneema rope to transfer the load to the deck and allow the entire keel box structure to carry load.
in either case I am planning on being fairly conservative - probably 4 supports each sized to take 100% max load. Was originally leaning towards the beams through keelbox option, but am hesitant to cut holes in it.
So before I get to any more detailed questions - has anyone got an informed opinion if either of those options is preferential.
A few people I mentioned this too got worried looks when I mentioned the dyneema option, but I am not sure this is just because it is different rather than a bad idea. The breaking strain on 10mm Dyneema is huge ~10,000 kg (and I will use 4 of them.
The keelbox is 1800mm high and 1100mm.
