Location of GM Transvers
Discussion in 'Stability' started by amateur mariner, Mar 25, 2009.
  1. amateur mariner
    Likes: 1, Points: 0, Legacy Rep: 30
    amateur mariner Junior Member
    Hi,
    I want to ask two questions
    1 Is there any periodicity for Inclining experiment?
    2 What is the analysis if GM transvers is slightly starboard or port of center line?
    Cheers
  2. Ad Hoc
    1. do you mean period as in roll period, or period as in time between having to perform an Inc. Expt?
    2. Is the TCG creating 0.0001 degrees list or 0.1, 1, 10 or 20 degrees???
  3. amateur mariner
    1. I mean periodicity of Incl. Expt.
    2. I want to know that if i get to know that my GM transverse is slightly stbd or port of centerline, what all affects it has?
  4. Ad Hoc
    1. If the boat has changed from its "launched" as delivered state. If the mass has increased and/or move items around on board which affect the GM, then you need to re do it.
    2. You can only tell, once you have performed the calc's what the effect is, and then ascertain if it is a problem.
  5. amateur mariner
    I have come to know that my Transverse GM is Port?How can I say it is a problem or not?What I should do to come to a conclusion?
  6. DavidJ
    Likes: 32, Points: 0, Legacy Rep: 441
    DavidJ Senior Member
    Transverse GM, despite what it sounds like, is actually a vertical dimension and cannot by definition be to port. You are referring to TCG or "transverse centre of gravity" like Ad hoc said and it is only a problem if it produces a noticeable list. Many boats launch with a slight list. Is this boat still in design stages or is it on the water? If you are already using it and you can't notice the list then I would guess that it is not a problem.
    You will only need to do a new inclining experiment if like Ad Hoc said there has been major changes in weight or location of weight.
  7. DEboater
    DEboater Naval Architect
    If you do the calculations and find out your TCG is not 0, and you think you may have transverse stability issues then you have to run through the appropriate stability criteria for your vessel to see if it has appropriate righting arm with statical stability curves. Use imo/CG/ABS/etc criteria.
  8. Guillermo
    Likes: 188, Points: 63, Legacy Rep: 2247
    Guillermo Ingeniero Naval
    Depending on each country regulations, some fishing vessels, houseboats and other floating structures are to be checked for adequate stability at 5 to 10 years intervals.
    Cheers.
