leave the dog alone or...
Discussion in 'Diesel Engines' started by tranmkp, Feb 7, 2008.
  1. tranmkp
    Likes: 2, Points: 0, Legacy Rep: 78
    tranmkp Junior Member
    Westebeke W-70 (70hp) 4500 hrs,
    compression is 460- 500-500-480 (checked thru glow plugs - injectors not removed)
    Starts and runs very well, no smoke - idle is smooth.
    PO says valves have never been adjusted nor have the injectors been pulled.
    So, do I leave it alone and dont adjust the valves or pull the injectors? Not familiar with the Westebeke (mitsubishi block?)
    I know I have to do it on my diesel cars -
    thanks in advance
  2. george allard
    george allard Junior Member
    Check and ajust the valve if needed. Leave the injector alone.
