Large Stability Calculation help!!
Discussion in 'Stability' started by Crodriguez, Mar 25, 2012.
  1. Crodriguez
    Crodriguez Junior Member
    Hi
    I´m a naval architecture student
    My doubt it´s about large stability
    whe the ship is inclined 20, 40, 60 degrees
    the vertical center of buoyancy (vcb)changes??
    Do I have to calculated at those degrees??
    thanks for your help! :D
  2. Ad Hoc
    Likes: 861, Points: 113, Legacy Rep: 2488
    HI
    Welcome to the forum.
    The VCG, or KG does not change, that remains constant, unless you have shifting cargo.
    But the VCB does change as does its location athwartships. This alters the waterplane area, at that draft/trim, which affects the location of KM. See the two diagrams below for ref:
  3. Crodriguez
    thanks for the help!!
    so if I wanna calculate large stability
    I´ve to calculate km and VCB
    at those degrees??
    ok it´s a long job
    but interesting
  4. Ad Hoc
    Yes, for large angle stability.
    This is where a software program is helpful. But since you're a student, you must be able to do this by hand calculations. Nominally use increments of 10 degrees for each. You'll end up with what is called cross curves of stability. Very time consuming to do...but essential.
  5. Pascal Warin
    Likes: 2, Points: 8, Legacy Rep: 38
    Pascal Warin Junior Member
    Additionaly for large angles change of trim may be important so you need to calculate with free trim method.
  6. TANSL
    Likes: 416, Points: 93, Legacy Rep: 300
    Do not complicate the live of our student. When using the computer, with a modern software, one can calculate the cross curves of stability considering trimming that takes the ship on each heel. When work is done by hand, which is what our student should do now, to carry out calculations with the trim could cost him some years.
  7. Pascal Warin
    OK but it is important that he knows that it exists.
  8. TANSL
    There are so many things (about how ships float) that exist and that we do not know!!!!. And despite of that, some of us continue desiging boats.
  9. Tim B
    Tim B Senior Member
    Rubbish. It's a volume integration and a 2nd order ODE. You don't need to handle obscure shapes for a proof of concept, so that makes the volume integral easy. This is where you need to understand what's going on, and how you use the computer to help. I.E. you understand the algorithm behind the interface.
    Come on guys, let's get the simple stuff nailed first!
    Tim B.
  10. TANSL
    I never said that calculations were complicated or difficult to understand concepts. All I meant was that, because calculate the equilibrium position (the trim) to each heel is laborious, calculations made ​​by hand, can last a long time. Otherwise, I agree with you, it's stupid to pretend that it is difficult what is simple and common sense. The term "rubbish" was not necessary to use it, does not contribute anything to this thread. Regards
  11. Crodriguez
    I finished my calculations, but I´ve a question
    what stability criteria do you consider the best'???
  12. Ad Hoc
    There is no "best" as such.
    You look at the technical Specification of the vessel, what is she being designed to satisfy?...that tells you what stability criteria is appropriate. For example, you would not use the HSC code on a container ship!
  13. zeozeovt
    zeozeovt Junior Member
    it depend on the loading conditions and the shape of hull, as u said that is really a long job to do. . .
  14. klaas
    Likes: 2, Points: 3, Legacy Rep: 24
    klaas Junior Member
    The criteria depends on the type of ship.
    For commercial ships the 2008 Intact stability code will give you a good start.
  15. TANSL
    I am attaching an Excel spreadsheet with a summary of the stability criteria that, depending on the type of boat, requires the Spanish Administration and another sheet with IMO criteria. As it is in Spanish, you will understand it perfectly
