Kevlar
Discussion in 'Materials' started by rberrey, Jun 26, 2011.
  1. rberrey
    Likes: 65, Points: 28, Legacy Rep: 112
    rberrey Senior Member
    In a hand layup on a foam core hull of a 5.1 oz kevlar should I use satin weave or plain? rick
  2. Eric Sponberg
    Eric Sponberg Senior Member
    It does not really make too much difference strength/stiffness wise. The satin weave will drape better over rounded shapes.
    Eric
  3. rberrey
    Thanks Eric.
  4. 22titanfisher
    22titanfisher New Member
    Who would be a good source for kevlar samples? I'd like to play with some before trying to lay up an entire hull.
  5. Eric Sponberg
    Try Composites One: www.compositesone.com. They are a major supplier of composite materials to all fiberglass industries. You will have to pay for it; they don't give them away for free, and that is IF they have any samples or cut-offs from other miscellaneous orders. Then, you can also try Googling "kevlar distributors" and see what you get. Kevlar is a DuPont product, so you may be able to find sources through DuPont.
    Eric
  6. LP
    LP Flying Boatman
