Keel cooler sealing advice
Discussion in 'Diesel Engines' started by cal_d_44, Jul 11, 2014.
  1. cal_d_44
    Likes: 1, Points: 0, Legacy Rep: 35
    cal_d_44 Junior Member
    Hi all, I am after some advice I have a Nanni 55 hp engine that is designed for keel cooling, the manufacture recommends 1.85 sqr/mtr of surface area for effective cooling at >18 deg C water temp, and as I will be sailing mainly in the tropics. I have built one side, and together it will have about 1.95 sqr/mtrs of surface area and hold around 20 ltrs of coolant total (inc engine). I have built one side and have pressure tested it to 20psi the overflow/heat expansion cap is pressure rated to 1bar/14.5 psi, now in over an hour it lost 0.5psi through two small pinprick holes that I can not get too to weld them effectively. Any advice on how I could seal them. Was thinking of filling it with a thinned oil base paint pressurising it and then draining and washing the paint out??? each cooler side hold around 4 ltrs. Any advice would be appreciated.
    Cheers
    Cal
  2. CDK
    CDK retired engineer
    2C epoxy adhesive can seal the pinholes if you can reach them with a thin object and the holes are dry. If you have access to a pump, pull some vacuum so the adhesive gets in all the way.
    If you have no access at all, use the stuff that seals car radiators.
  3. cal_d_44
    Cheers CDK :idea:
  4. gonzo
    Likes: 2,294, Points: 123, Legacy Rep: 2031
    The engine will overheat in tropical shallow waters. They can get to over 30C. Also, any coating you put in the heat exchanger will lower its heat transfer rating.
