richard gray
- Mar 3, 2013
- Messages
- 64
- port coquitlam
Hello: I have an amphibious vehicle project started ( 20 ft aluminium cat hull ,with wheels tucked in the sponsons) the drive line is to use an auto (jeep) dana18 transfer case powered by v8 to drive the jet drive. the transfercase was reversed so the old input(reardrive is now the output & the old input now is to drive jet pump) the question is if the transfercase is shifted into low it now is spinning 2to1 faster (like an overdrive, the the low gear has half the teeth) should work great in high gear(1to!}.the 2to1 may be to high and would require more H.P. and torque?
