Bazza, you said :
"First off I am trying to design a hull for this jet boat. I need to understand what angles for the hull transom etc are suitable and why, what curves for the front are suitable and why. I have been looking at the shape of the underside rear of the hull and they angle back down. So shape and dimensions of the hull are my first objective. I guess then I will need to understand the structural strength and support I need for the hull and so it goes on. If you have a book suggestion or other suggestion I would appreciate it."
These type of boats are complex little beasts to design well, and when you introduce water jet propulsion (rather than a 'simple' outboard motor) they become even more complex, with more chances of getting it wrong.
Rather than a book, my suggestion would be to buy a set of plans re a boat that has been proven to work - maybe even buy two sets of plans for different boats that you like.
And use these as reference for designing your own boat.
Your boat will probably end up very similar to the boat(s) you are using for reference.
It might even be exactly the same.
But you will have got some experience of drawing and figuring out the 'why, what and where' behind it.
Pretty much all boat designs start off with a basis vessel which is then tweaked slightly to suit the SOR (eg make it a bit bigger, or smaller, more or less deadrise etc) - very few boats start off as a completely blank sheet of paper (or a blank computer screen). There is no 'shame' in copying an existing boat - you do not have to re-invent the proverbial wheel by thinking that you have to start from scratch for it to be 'your' design.
If you want to learn the basics of naval architecture or yacht / boat design to help you better understand your boat plans, there are many excellent books available on
www.amazon.com - do a search.
