Jack Up Repair
Discussion in 'Class Societies' started by naserrishehri, May 17, 2014.
  1. naserrishehri
    Likes: 1, Points: 18, Legacy Rep: 10
    naserrishehri Senior Member
    DEAR FRIENDS
    I'm looking for a check list containing common repair items of a jack up during dry docking? would you please help me?
    Likes: 1,726, Points: 123, Legacy Rep: 2031
    What do you mean a "jack up"
  3. powerabout
    powerabout Senior Member
    jack up drilling rig I assume
  4. PAR
    Jacking could also refer to putting the boat on stands.
  5. NavalSArtichoke
    Likes: 9, Points: 0, Legacy Rep: 83
    NavalSArtichoke Senior Member
    That's what a survey is for: to tell the owner what maintenance items need addressing while on dock.
  6. powerabout
    re-plate the whole bottom
  7. Mr Efficiency
    Puzzling the way people involved in commercial operations ask vague questions on an internet forum. You blokes will be to blame if he misses something on the checklist !
  8. boatbuilder41
    Likes: 8, Points: 18, Legacy Rep: 56
    boatbuilder41 Senior Member
    Is it a jack up bqrge that is self conntained??. generators. ?? Propulsion??? I have seen them as bare barges... and with twin inboard diiesels. . keel coolers ???
  9. Mr Efficiency
    No more heard from the OP, obviously being held in a secure facility where you are allowed only one phone call or electronic message. Judging by the number of similar threads, the facility is well populated.
  10. Ad Hoc
    Likes: 1,688, Points: 113, Legacy Rep: 2488
  11. rxcomposite
    Likes: 608, Points: 113, Legacy Rep: 1110
    rxcomposite Senior Member
    He probably meant this, a jack up rig. The legs are stowed on deck and are assembled by connecting/lengthening/jacking up, on site. It is towed to the site by tugboat(s). This is a common view in the gulf area with the rig lining the skyline. Here you see the jack up in the harbor awaiting repair, maintenance, or survey.
    A smaller one is called a jack up barge.
  12. rxcomposite
    Just to give you an idea of size, this is a part of a leg in the unfinished state.
  13. naserrishehri
    I,m looking for a check list like the attachment. jack up rig is different from a ship and it has many different equipments. I like to use a repair shipyard,s experience which repair jack up rigs.
  14. rxcomposite
    The check list is typical of a surveyors "code". Here is a much more detailed list of a typical survey. http://thuledrilling.files.wordpress.com/2011/10/bevis-29-b.pdf
    You will need a marine surveyor to do the job first like somebody from Noble Denton.
    As for shipyard repairs, it depends on where the rig is as it needs to be towed. I see much rig in Sharjah and Abu Dhabi. Seems there are a lot of shipyards especializing on repairs of oil rig.
  15. naserrishehri
    thanks a lot rxcomposite
