Is there a difference in naming convention in NEMOH and WAMIT regarding the Diffraction Potential
Discussion in 'General Computing' started by Chaitanya Kesanapalli, Sep 12, 2021.
  1. Chaitanya Kesanapalli
    Chaitanya Kesanapalli New Member
    I am new to Boundary Element Method, and I recently learned both WAMIT and NEMOH. But in the documentation, I see different naming conventions for Diffraction potential
    In WAMIT, https://www.wamit.com/manualupdate/v74_manual.pdf
    Diffraction potential = Incident + Scattered
    Total Potential = Diffraction potential + Radiation potential
    Diffraction force = Froude Krylov force + Scattered force
    Where as in NEMOH and some other books such as sea loads on ships and offshore structures by OM Faltinsen and http://web.mit.edu/2.016/www/handouts/2005Reading8.pdf, http://web.mit.edu/13.021/demos/lectures/lecture21.pdf
    Total Potential = Incident + diffraction + radiation
    Also
    Excitation force = Froude Krylov force + Diffraction force
    Am I wrong?
  2. jehardiman
    Likes: 1,326, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    If you are in school or an office, use the terminology they want you to use so you can communicate better. Otherwise, use terminology that helps you understand the separate components of the theory. Every hydrodynamicist must come to his own understanding of the differing theories and methods. If you don't understand the theory differences, then the terms used by any program aren't going to be helpful.
  3. Dolfiman
    Likes: 681, Points: 113
    Dolfiman Senior Member
    Here is a powerpoint presentation of Nemoh by their authors (and their email adresses in case of) , may be you will have your answer and more :
    BabaritpresentationEWTEC2015.pdf
