Interesting information, Will. Thanks for digging it up. It certainly seems plausible that significantly more energy will reach Earth's surface if/when Earth's magnetic field diminishes during a reversal. From your links it doesn't appear that most scientists think that the weakening of Earth's magnetic field can account for the current spike in temperatures.
Reversal occurrences are statistically random.....sources estimate that the time that it takes for a reversal to complete is on average around 7,000 years for the four most recent reversals. Clement (2004) suggests that this duration is dependent on latitude, with shorter durations at low latitudes, and longer durations at mid and high latitudes.
[2] Although variable, the duration of a full reversal is typically between 2,000 and 12,000 years.
[3]
[During reversals Earth doesn't completely loose it magnetic field, but it become very mixed up, with numerous "north" and "south" poles]
Effects on biosphere
Shortly after the first geomagnetic polarity time scales were produced, scientists began exploring the possibility that reversals could be linked to
extinctions. Most such proposals rest on the assumption that the Earth's magnetic field would be much weaker during reversals. Possibly the first such hypothesis was that high-energy particles trapped in the
Van Allen radiation belt could be liberated and bombard the Earth.
[44][45] Detailed calculations confirm that if the Earth's dipole field disappeared entirely (leaving the quadrupole and higher components), most of the atmosphere would become accessible to high-energy particles, but would act as a barrier to them, and cosmic ray collisions would produce secondary radiation of
beryllium-10 or
chlorine-36. A 2012 German study of Greenland ice cores showed a peak of beryllium-10 during a brief complete reversal 41,000 years ago, which led to the magnetic field strength dropping to an estimated 5% of normal during the reversal.
[46] There is evidence that this occurs both during
secular variation[47][48] and during reversals.
[49][50]
Another hypothesis by McCormac and Evans assumes that the Earth's field disappears entirely during reversals.
[51] They argue that the atmosphere of Mars may have been eroded away by the
solar wind because it had no magnetic field to protect it. They predict that ions would be stripped away from Earth's atmosphere above 100 km. However,
paleointensity measurements show that the magnetic field has not disappeared during reversals. Based on paleointensity data for the last 800,000 years,
[52] the
magnetopause is still estimated to have been at about three Earth radii during the
Brunhes-Matuyama reversal.
[44] Even if the internal magnetic field did disappear, the solar wind can induce a magnetic field in the Earth's ionosphere sufficient to shield the surface from energetic particles.[53]
Hypotheses have also advanced toward linking reversals to
mass extinctions.
[54] Many such arguments were based on an apparent periodicity in the rate of reversals, but more careful analyses show that the reversal record is not periodic.
[19] It may be, however, that the ends of superchrons have caused vigorous convection leading to widespread volcanism, and that the subsequent airborne ash caused extinctions.
[55]
Tests of correlations between extinctions and reversals are difficult for a number of reasons. Larger animals are too scarce in the fossil record for good statistics, so paleontologists have analyzed microfossil extinctions. Even microfossil data can be unreliable if there are hiatuses in the fossil record. It can appear that the extinction occurs at the end of a polarity interval when the rest of that polarity interval was simply eroded away.
[25] Statistical analysis shows no evidence for a correlation between reversals and extinctions.
[56][44]
