Is power catamaran capsize safer than sail catamaran?
Discussion in 'Multihulls' started by gp333, Jan 29, 2012.
  1. gp333
    gp333 Junior Member
    I believe yes, but wish ask more experienced here...
  2. CatBuilder
    CatBuilder Previous Member
    They say yes, power is less likely to capsize.
    Why?
    First of all, you can't have a wind induced capsize from too much sail up in windy conditions. This is the most common reason for catamaran capsize.
    Second, you have a lot of weight down low in the form of engines and fuel. In addition to the dimensional stability of the two widely spaced hulls, this gives you even a bit better of a righting moment from weight distribution as well. A sailing cat, in most instances, will have a center of mass that is a bit higher up than a power cat.
  3. gp333
    gp333 Junior Member
    And if power catamaran capsize, he stay capsized too? Or hard sea can alone latter back him in normal position
    maybe?
  4. PAR
    If any catamaran capsizes it's a bad day, power or sail. Neither recover very well and no they will not "self recover" without the assistance of a big crane or hurricane whipped seas.
  5. gonzo
    It depends on the design. The method of propulsion alone is not enough to determine an answer.
  6. eyschulman
    Likes: 8, Points: 18, Legacy Rep: 77
    eyschulman Senior Member
    What Gonzo says gatta be true- I have seen some power cats with so much freeboard and house area you might as well have a sail you can't take down.
  7. gp333
    gp333 Junior Member
  8. gonzo
    There isn't a tradition on power catamarans yet, they are new-comers.
  9. gp333
    gp333 Junior Member
    yes, but planet solar is extremely "new-commer"
    any ideas about his hard sea stability?
  10. sandy daugherty
    Likes: 4, Points: 0, Legacy Rep: 52
    sandy daugherty Senior Member
    Ask anyone from Kansas; barn doors do fly. So this example is probably not the best way to survive heavy weather. I suspect only an enclosed, self propelled life boat, painted international orange is the best bet.
    Add another consideration to your powercat question; beam. There are examples of production powercats with beams narrow enough to fit in a large slip. They may be two or more stories high ( but none to my knowledge have elevators or escalators YET.)
    Others may not have enough power to keep the bows into the wind in a stiff blow.
    The last consideration is training. I'm sure that anyone who can carry a 4 x 8 foot piece of 3/4" plywood on his head across a frozen lake in a blizzard could handle that PlanetSolar very-nearly-a-trimaran in a blow.
    Naval architects use a related term, Metacenter, to talk about this problem. It's not hard to come up with.
    Gonzo: I'm looking at a powercat built in 1962. Isn't 50 old enough?
