DCockey
Participant
- Joined
- Oct 24, 2009
- Posts
- 5,309
- Reaction score
- 682
- Location
- Midcoast Maine
Yes - the arrows are uniform in length but the color indicates the magnitude of the velocity.
Thanks. What is the speed of the airfoil(s)?
Note: This feature may not be available in some browsers.
Here's a run on 2 sails, to see if the jib really has its own circulation like Arvel Gentry professed in 1971 or so (http://www.arvelgentry.com).
This is all experimental and unlikely to to pay off.
...The first animation shows velocity vectors, and the second markers moving with fluid.
What determines the orientation of the markers in the second video? Are they aligned with the velocity vector, or do they represent the rotation of the fluid at that point?
I would think the flow around the leading edge would be irrotational - moving in circles, but not changing orientation. But the markers circulating the bound vortex appear to have similar orientation to the markers in the starting vortex, which should have a viscous core with rigid body rotation.
To summarize, I feel that the simulations would suggest that the circulation theory of lift is more than just a theory - that it actually explains how lift is created. When the wing starts from the rest, the flow is accelerating at the trailing edge more rapidly on the pressure (lower) side than on the upper (suction side), simply because under the foil the flow has "a straight road" to the trailing edge. This creates a shear layer between the upper & the lower surface, extending from the trailing edge. The shear layer rolls into the spiral "starting vortex", and the starting vortex creates the circulation in the opposite direction, around the foil, while itself being left behind.
There's nothing new in what's said above, but usually the circulation model is dismissed as "a mathematical model and theory, which just happens to yield results close to experiment". A hundred years ago, as explained by David Bloor in "the enigma of the airfoil", the theory was overlooked by the British Cambridge School, since it was based on an inviscid flow, where no vortices could form or decay, thus unrealistic. More recently, I think it has been overlooked because most often the flow over an airfoil is presented in a coordinate system moving with the foil, equivalent to the wind tunnel experiment, where the foil is stationary and the fluid is moving. This way, the true circulatory nature of the flow is masked by the free stream superimposed on it. When the fluid is stationary and the foil is moving, the circulatory flow pattern is revealed. Circulation is real.
We are back on the page 1 of the thread...Is anyone disagreeing with the statement "Circulation is real"?
