cavalier mk2
Senior Member
- Joined
- Mar 14, 2010
- Posts
- 2,266
- Reaction score
- 147
- Location
- Pacific NW North America
i should admit to preferring meranti ply these days.
Note: This feature may not be available in some browsers.
My wood resource lists white pine at 24lbs/cu-ft. and cyprus at 28lbs/cu-ft. Both species are listed as not strong but durable with the cyprus having the edge in rot resistance. However, cyprus can have hard and soft streaks because of the difference between summer and winter wood so if you can't pick through it maybe pine is the best choice. Is it much less expensive where you are? In my part of the woods I usually use red cedar, Douglas Fir and Sitka Spruce depending on the job. Wherever you are local woods are the way to go.
I too, am looking to make this with minimal expense. Although I am in disagreement with many on this forum, I don't include the cost of my labor. I happen to consider my time on this as enjoyable and part of the hobby. If I hated wood working (or this design work for that matter) I guess, I would consider it part of the cost. At which point... this would be a very expensive boat!
But, as I see, we are in similar shoes... you might want to consider the Lindsay Lord strip plank technique as described by Dave Gerr. It proports to make an extremely light and inexpensive hull.
Printed out Lee Hull Stations
Tried and tested works too...
...However, if you are an engineer, designer, architect, inventor, tinkerer, or scientist the fabrication and experimentation, is half of it.
The best method is called the blender method.... it looks at al that has gone before - adds what is new , compromises what is yours or new and or crazy and comes out with a result that may work - way out and experimental are interesting and wonderfull if they work and forgotten if they dont.
People have been building boats for a really long time...... you are not the only genius?
Or maybe experience is uncalled for and others are stupid and you are clever.... balance and moderation are not always a waste of time.
There is a reason why people make living from this and most people buy plans...... there's more to it than meets the eye?
Dont discard what has gone before bacause it is boring or doesn't suit you - it has been hard learnt and we learn from it.
... Aluminum is stiffer than steel...
Fact: for a given weight.... aluminum is stiffer than steel (due to cross-sectional area)
