Ignition lanyard
Discussion in 'Powerboats' started by Thunderhead19, Aug 2, 2005.
  1. Thunderhead19
    Likes: 3, Points: 0, Legacy Rep: 21
    Thunderhead19 Senior Member
    Does anybody here know if there are any US regulations that require the use of an ignition shut off lanyard? I found a requirement in ABYC for the use of these lanyards on light jet boats, but I need something in writing that confirms that there is no requirement. That is a bloody tough thing to get....that is, a document stating that something is NOT legally required.
  2. Thunderhead19
    I'll keep everyone posted when I get this sorted out.
  3. gonzo
    Likes: 1,726, Points: 123, Legacy Rep: 2031
    It is legally required in boats of less than (I believe) 19'. You can check the length with the USCG
  4. Thunderhead19
    My problem is with a 29' cabin cruiser with twin outboards.
  5. yipster
    Likes: 97, Points: 58, Legacy Rep: 1148
    yipster designer
    deadman ignition killer switches are mandatory on fast boats (here)
  6. Corpus Skipper
    Likes: 8, Points: 0, Legacy Rep: 173
    Corpus Skipper Hopeless Boataholic
    Any boat I've ever seen with outboards had kill switches simply because they came with the engine or were built into the control box. At 29 feet the boat should be yacht certified and kill lanyards are not required. Check the CG plate and if it says yacht cert. then you're in the clear.
  7. Corpus Skipper
    Oops, I just saw you're in B.C. so I haven't got a clue :D
  8. Thunderhead19
    actually it's for an american customer in alaska
    thanks for the info
